1975 f-100 with 360 2 bbl
Old Feb 20, 2010 | 12:36 AM
rspreston63's Avatar
rspreston63
how do i hook up the electric choke that the truck came with? some one put a manal pull cable I took it off and need to hook up the vaccum hose but to where?
Old Feb 21, 2010 | 10:55 PM
amish77's Avatar
amish77
Electric choke shouldn't have a vacuum line to it, just an electric power line. Maybe I'm wrong here, but I think that you should just have to hook up a switched 12v to the choke, a little adjustment, and it should be all smiles.
Old Feb 21, 2010 | 11:17 PM
rspreston63
it's an old 2150 motorcraft the choke pulldown needs a vaccume line to engauge fast idle diaphram i think
Old Feb 23, 2010 | 04:11 PM
amish77's Avatar
amish77
Well if you see a vacuum port on the choke I'd find an open vacuum source and try it, but remember what you did, so you can go back if this doesn't work. They make "t" fittings that you can use to splice an existing vacuum line to make a new vacuum source if you can't find one. I'm used to Holleys, Carters, and Edelbrocks, which all have that vacuum system internal to the carb.
6.9idiatsturbo
Jun 22, 2011 10:54 PM
btm991
6.7L Power Stroke Diesel
19
Mar 6, 2011 05:59 PM
esco24
Oct 24, 2009 07:08 PM
MMiller528
Sep 18, 2004 08:51 PM
beartracks
Apr 4, 2001 01:50 PM
