Sponsored by: Real Truck
02 v-10 slowly lost power
Old Jan 30, 2010 | 09:18 AM
Andy's250's Avatar
Andy's250
hey guys im usually in the powerstroke forum but my dad is having some problems with his 02' v-10 f-250. He was headed home about 10 miles away yesterday evening. he said it slowly started losing power. at first you could still give it about 3/4 throttle, over the ride home it slowly got worse and worse. wen he got home it would barely run 15-20 and if your throttle it much it dies out. i'm thinking he needs to put a fuel filter in it, as it has 150k on it and he cant remember last time he put one in it. the truck is all stock and he just uses it for work. thanks for your help guys im hoping i can get it back on the road pretty quick
Old Jan 30, 2010 | 11:21 AM
VAXB's Avatar
VAXB
Fuel filter would be where I'd start. Then maybe have the convertor checked
Old Jan 30, 2010 | 11:41 AM
Andy's250's Avatar
Andy's250
sounds good, thanks
Old Jan 30, 2010 | 12:12 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea change that fuel filter and check the air filter while your at it.
Old Jan 30, 2010 | 01:47 PM
Andy's250's Avatar
Andy's250
he changed the fuel filter and it seemed to help some. it'll go about 40 now but still not right. i told him to check the air filter next. is there any way to check the cat myself?
Old Jan 30, 2010 | 01:55 PM
simply_peter's Avatar
simply_peter
I have a 99 V10 doing the same thing. Idles fine just seems like it doesn't want to go when you push on the gas. Was checking to see if there was any info on here and found your post.
What do you check for in the cat? Is it flow restriction? Or something else?
Old Jan 30, 2010 | 02:08 PM
Andy's250's Avatar
Andy's250
i would guess it is flow restriction. on my truck you just beat all the ***** outta the cat and put the shell back in line but i dont think you can do that on these gas trucks. this site is a wealth of knowledge im certain our ford brothers will help us figure this out peter and welcome to FTE , glad to have you here
Old Feb 2, 2010 | 02:17 PM
Andy's250's Avatar
Andy's250
bump. i found out the fuel pump is bad, does any body know how hard it is to repalce in these trucks? some people told me it was easier to just pull the bed
needhelp49
Modular V10 (6.8l)
Jun 18, 2015 12:56 AM
V10 Driver
Modular V10 (6.8l)
Dec 11, 2013 12:29 PM
handyman43358
Feb 13, 2013 07:16 PM
rosett
Aerostar
Jan 26, 2010 02:10 PM
Andy's250
Nov 3, 2009 05:45 PM
