302 oil pressure phenomenon
My 1969 F100 has 267,000 miles on it and a 1979 302 transplanted into it. The wrecked 1979 donor car had a transplanted engine (unknown miles)but ran great so I put that engine into this truck (changed it over to truck oil pan, timing cover, etc). Three years ago on a interstate trip, I noticed that the oil pressure would rise 10-12 psi on deceleration at 50 mph, and return when either the engine speed slows down, or I step on the gas again. The engine has been doing this for 100,000 miles without any long-term drops in oil pressure (bearing wear). I use a S-W mechanical oil pressure gauge, and I am confident that it is accurate. The truck has a 4spd with 2.75 gears, so sudden engine speed changes with throttle position changes are negligible. Since oil pressure is higher with high vacuum, I removed the PCV valve, and that had absolutely no effect. I suspected a suction leak on the oil pump, so I replaced it with a new Melling H-V oil pump - that raised the oil pressure (obviously) but did not change the symptoms. The engine oil pressure hot is 20psi idling and 40psi running @ 2000 rpm. I use 30W oil year-round (same thermostat) and use a block heater for cold winter starts. I have asked several knowlegeable engine people, but no one has an explanation. I don't want to tear this engine apart just to find the cause, since it is my daily-driver. I have also seen this on a friend's high mileage 1979 302, but have not had to repair that engine yet. Anyone out there got any ideas?
Art
artjz@twindisc.com
1969 F100 2WD 302/4spd
1969 F250 4WD 440/727
1979 F250 4WD 400/C6/Trac-loc Dana60 F&R
1934 Ford sedan 392hemi/clutchflite
and also tons of 67-79 Ford truck parts
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
I already ruled out oil pump starvation, as when I apply the brakes without lifting on the gas, the oil pressure is rock-steady. Over-filling the engine by 1qt. doesn't change anything either. Thanks for your input anyways.
jowilker:
I know it isn't broke and I plan on running it until it either blows up or quits running. It's just something I noticed and haven't been able to answer. Don't worry, I have lots of hobbies, like my 1969 F250 4x4 and my GM KILLR (that's what the tags say) drag car. I just figured I'd run into someone with the answer.
Art
