not hearing turbo whistle..... is that normal...
Yep, that would be a good start I think. Don't worry, good chance its just a dirty filter.
Don't mean to jack this thread but my wife's truck seems a little low on power and boost doesn't build up much over 5psi (according to the autometer gauge i have hooked up and I think its a psi or two low). There is also a bell ringing noise heard around 1600-1800 only under load (in gear powerbraking or in that rpm range going down the road). Haven't devoted much time to really looking into the problem because the check engine light never comes on and the truck seems to get along ok.
yes.. I believe I have power problems and my mpg always seem to be a challenge... 14/16 mpg is normal (if I'm towing it will drop to 9/13).
No I dont seem to feel the boost of the turbo unless the engine is just started and cold.
I have recently added the 6637 intake mod and do hear the drone of the air filter.
Which vacuum line are you talking about? do you mean the red line going to the waste gate?
This is the first thread I could find that was close to the topic I'm concerned with- I have a '99 F-350 4x4 crew cab with a 6-spd man. and lately it's been making a hissing noise under the dash when the throttle is anywhere but at idle or wide open, and the power drops when the noise starts. I've checked the red line running to the wastegate actuator and it seems OK- does this sound like a bad or sticky actuator? What's that switch with the two wires and two little hoses coming out of it?
Thanks for any help with this
Nick9219
17
09-12-2021 11:40 PM
BogginDave
12-30-2015 08:21 AM
