id say 315/635
and start with the highest tune , on the worm engine, do it twice, than fiddle with other tunes. make sure the engine is up to full operating temp.
if i were you i would not waist time on low tunes . go all out
do one pull with o/d on, and one with it off. now third pull with next setting down - do it with whatever o/d combo give you better# . and you all set.
o/d on off varies dyno to dyno.
id say with od on you should be able to load down the engine better.
see for yourself.
all trucks are like woman, all the same gender , but like diferent handling
see what yours like.
