I need to replace my 4x4 switch instrument panel light. I checked online and found scattered info ... but stumbled onto this site: Autolumination Instrument Panel Light Bulbs & Lamps
Scroll down to the section: Neo - Wedge Tall Glass Instrument Panel Bulbs
They have both LED and standard bulb options and as near as I can figure it fits their criteria with measurements but the site does not have complete cross reference lookups for make and model.
I would like to know if this is the right bulb/bayonet base? Anyone have any experience with this?
Other sites have complicated bulb replacement directions that reuse/refit your old bayonet base ... this looks like a $1.99 solution !
When the 4x4 switch bulb went out on my 97 Ford only serviced the bulb in the switch assembly.
Lucky for me I worked in parts, removed the old bulb and found that Ford part number F8RZ-13B765-AA was a direct fit as a replacement bulb.
