Temp guage goes up and down and sporatic heat
'95 EB Bronco, 351, 150k miles.
My GF has been driving the Bronco this winter, but we just switched. Very cold here in Michigan now, and so when I went to drive it yesterday, I noticed it didn't give out any heat in the first 5-7 minutes. (its usually unbearable by this time).
I then noticed the guage rising to the far right (overheat). Started to worry, then all of a sudden it dropped way back to the left -- then heat blows. Moments later, back to the right, and no heat.
Did this the whole way home (20 miles). I asked the GF and she said this has happened all winter. (why did she not complain about no heat? i dunno. oh well).
Haven't even opened the hood to check anything, but isn't this a Thermostat 101 issue?
IF that doesn't solve it, check for a plugged heater core (for the heater at least) by getting the engine hot and then feeling the in and out hoses on the heater core. If ones hot and ones cold, it's plugged.
Lastly, stock gauges are known for this problem. They fluctuate on my '81 as well. Next time it goes up, see if your fuel gauge and oil gauge read a little higher than they did before, and a little lower after the heat drops back down. If so, your voltage regulator inside the dash is going finicky. Not necessarily important to change, but you'll know why things act the way they do.
Check the coolant level with the truck cold at the radiator cap NOT the overflow reservoir. The reservoir can show everything as being fine simply because most people check the coolant before they go anywhere so the t-stat is closed and there is enough coolant for the system this way but not when the thermostat opens.
I'm not saying you don't have a dead/dying thermostat by now anyway. I merely suggest that the symptoms are indicative of this unique issue. I would be interested to know for certain. So if you check things out, let me know what you find.
BTW, the fix for this problem requires filling the system at the radiator cap with the engine cold but running. Once the radiator is full to about an inch below the surface that the cap seals against, let the truck run until the thermostat opens. If my theory is correct, you will need to add coolant again after it does. Once you have topped off the system at the radiator cap, replace the cap and top off the reservoir to the "full hot" mark. Keep any leftover coolant in the truck with you... that much coolant has to have seeped out somewhere... keep an eye on it.
I thought GreyStreak was onto something when I read his post, but thought I'd just change out the Thermostat for extra measure.
I finally got to digging into it, but its pretty dang cold here and have no garage heater... anyway, when I tried to tackle it this morning, I couldn't get the dang hoses off the block, off the water pump, etc. Just too cold to mess w/.
At this point, I decided to actually check the coolant level w/ a flashlight. It was down. Way down, and reservior empty too. I reread GreyStreak's post and thought that was it, so I didn't mess w/ replacing the Thermostat.
First, I started engine. Cold. I filled the radiator up to about an inch below the rad cap. I let the vehicle run for a while (5-10 mins idling). No heat yet in the car, and I kept checking temp of coolant in rad w/ my finger w/ the cap still off. Nice and green w/ the new fluid, and it remained cold. Temp guage in car stayed far left. (cold).
After 10+ minutes, things began to happen. Guage in car started to goto the right (hot). Then I have to assume the thermostat opened (or began to open) cuz the water turned an ugly color (dark, gray color). Then the water level dropped down, way down... I poured the rest of my 50/50 mix in there, and checked guage -- it was back to the left (cool), and heater was blowing hot. Water level was still very low, so I went into house to mix another batch of 50/50 from a fresh gallon of coolant. Car was still running. I returned and immediately filled the rad back to to top. (I had not put the cap back on yet).
At this time I noticed the reservior was half full of ugly colored coolant and also noticed coolant spray over passenger side of engine. I looked at ground and noticed a huge puddle of water as well. HHHmmmm... I filled the radiator up and put cap back on.
Now is when I came in here to type this.
The car is running now, the temp guage reads normal (to the left-ish), and the heater is blowing hot. Gonna let it run a while (while i type this) then go back out and see if I can see where it all blew out from (it is possible that it burped while I wasn't around).
Maybe I overfilled it w/ cap off? I dunno.
So far, I've probably added 1.5 bottles of 50/50 mix to it.
If I can't figure it out, then its going to the garage down the road -- the dreaded step of admitting failure. Haha.
Thanks, everyone.
Cannot find any leaks anywhere -- car has been running for ~20 mins w/ no issues. It must've just burped/overflowed when I wasn't around.
mprice is right, having been that low, she's gonna burp and bellow air for quite a while... The suggestion would be to have a couple of gallons of coolant with you and check the reservoir each time you reach your destination. Periodically, check the radiator level at the cap with the engine cold to be certain you maintain enough coolant in the system to actually make the syphon work between it and the reservoir.
I checked it after running around in the car today, and the reservior was empty, so I half filled it. Will keep coolant on-board as recommended.
I honestly don't know how long its been since coolant had been checked or serviced. I could've be years and years -- just got the Bronco from my mom this past May.
Thanks so much again.
Andrew.
