Fuel Bowl Plug O-ring's
Old Dec 26, 2009 | 09:15 PM
Bigcat350's Avatar
Bigcat350
Any one no what the # or what size orings go on the 2 3/16 fuel bowl plugs. I want to change them when I change my filter next time(soon). If you know what size for all of the orings I can use that also. I just fixed the drain lever this week and thought about pulling the bowl and replacing all of the Orings.
Old Dec 26, 2009 | 09:33 PM
duck fan's Avatar
duck fan
Because racetruck
When my drain valve went bad, I ordered Guzzle's fuel bowl O-ring kit from Riffraff. It had all the O-rings in it: Riffraff Diesel: Complete Fuel Bowl Seal Kit
I know you already did the drain valve, but this kit will have all the stuff you need
Old Dec 26, 2009 | 09:34 PM
CPUNeck's Avatar
CPUNeck
#4 O-ring boss. Should be the size for all the O-rings (not the vibra-loc stuff), the lines that feed the engine are 1/8NPT.
You should have two plugs on the rear, as you can see, I use one to feed the engine.
Old Dec 26, 2009 | 09:36 PM
SpringerPop's Avatar
SpringerPop
Take a look at Guzzle's PDF for rebuilding that fuel bowl.
He's also a good source for the o-rings necessary to do the job.
http://www.dieselorings.com/docs/FuelBowlRebuild.pdf
Pop
Old Dec 26, 2009 | 09:47 PM
Bigcat350's Avatar
Bigcat350
Thanks CPUNeck Thats what I am looking for, the size.
Pop
Thanks Pop Yea Guzzles sight is also great if you need the instructions or the orings he is also sponsor. But I have a oring shop down the road where I can get them on my way home for .30-.50 cents each and they are Viton also.
Old Dec 26, 2009 | 10:53 PM
Bigcat350's Avatar
Bigcat350
CPUNeck you think it takes a size 4 oring for the 2 plugs in the rear of the bowl?
Old Dec 27, 2009 | 08:19 AM
CPUNeck's Avatar
CPUNeck
Yep, I have a #4 O-ring boss -->> #6 JIC adapter in the picture for the feed of my fuel manifold. (I'm pretty sure for this application an AN-04 would work also) The other plug located closer to the top is the same. I just bought a supply of O-rings from and online vender (Vioton), so anytime I have to replace a failed Buna or Buna-N, it's with a Vioton.
chunt
24
Apr 25, 2016 08:11 AM
ron's power stroke
20
Dec 8, 2011 02:11 PM
TexasRenegade
Jul 30, 2011 06:09 PM
Powermonger
May 14, 2011 06:39 AM
brandon_oma#692
Jul 13, 2009 12:49 PM
