Radio/Clock resets regularly
Old Dec 7, 2009 | 10:00 PM
dcsmith's Avatar
dcsmith
Here lately, my radio resets to AM 590, the clock goes to 12:00 and the CD player seems to start reading each CD. This happens when I start the truck, mostly first thing in the morning. The presets don't get lost on the radio stations. It just goes to 590 AM. That is not a preset, nor is that a viable station in the area.
Any Ideas as to what is causing it?
Any help would be appreciated.
Thanks,
David
Old Dec 7, 2009 | 10:21 PM
javieljb's Avatar
javieljb
I would start with the battery. Have you changed the battery since you bought it? 4 or 5 year battery seems like it might be a bit old and weak. I would think the voltage is getting too low and the radio is resetting. May also look at the battery connectors to make sure the are clean and making good contact.
Old Dec 8, 2009 | 12:45 AM
dzap8490's Avatar
dzap8490
Stereo systems have two power source wires. One (usually red) is for ignition power, that is, it only has power when the key is in the ON position. The other (usually yellow) is a constant 12 volt source. There may be a bad connection on your constant wire. I've had it happen to me before.
Old Dec 8, 2009 | 02:48 PM
GwarForAll1021's Avatar
GwarForAll1021
yea its your battery. mine did the same exact thing when it went bad. started up ok but it would reset my radio. when it finally starting being sluggish on the start up it had to go. just fine now.
Old Dec 8, 2009 | 06:01 PM
dcsmith's Avatar
dcsmith
Thanks for the replies. The truck does start right up. I have an amp for the speakers and the Bazooka tube (2nd amp). That all seems fine.
I wonder if I could have the battery tested?
Old Dec 8, 2009 | 06:53 PM
GwarForAll1021
yea any local autoparts store can like advance discount...
if its not rolling over pretty fast id say its done for.
Old Dec 8, 2009 | 06:59 PM
dcsmith's Avatar
dcsmith
It cranks like it is brand new.
Old Aug 4, 2017 | 06:10 PM
moonpoo's Avatar
moonpoo
Thanks,
David
d.c. smith... did you ever figure out what is going on? our 2009 f250 does this!!!!!! not everyday but often!!!
Old Aug 5, 2017 | 01:13 PM
46fordtruck's Avatar
46fordtruck
Dcsmith hasn't posted on this site in about 4½ years, but you might want to check out the Super Duty/Heavy duty group here, I'm sure somebody would know. Good luck
Old Aug 5, 2017 | 07:06 PM
dcsmith's Avatar
dcsmith
It was the battery
Bought a new one. It was fine.
dragstang86
May 26, 2019 06:24 AM
ferretface
Escape & Escape Hybrid
Nov 7, 2017 09:16 PM
johnkn
2011 - 2019 Explorer
Oct 28, 2017 10:24 AM
doc4bax
Jun 1, 2017 12:40 PM
1995 ford
Aftermarket Products
Dec 20, 2016 01:43 PM
