4X4 Electronic Module
You could change this out yourself, but they're kind of a pain to access. If you're willing to give it a shot, do a search and you'll find all sorts of info.
Who ruled out a bad dash selector switch or the shift motor? Was this a dealer with the proper scan tools, or a local mechanic that was just making an educated guess?
I found a TSB on my truck and the problem with the 4x4 light flashing and the hopping while turning are 2 symptoms listed on the TSB. Do you still think it could be the shift motor? Thanks for the help.
TSB:01-14-1***ELECTRICAL - ELECTRONIC SHIFT ON THE FLY (ESOF) TRANSFER CASE - INADVERTENT 4X4 HI OR LOW SHIFT EVENTS ***TRANSMISSION - TRANSFER CASE - INADVERTENT 4X4 HI OR LOW SHIFT EVENTS - VEHICLES EQUIPPED WITH ELECTRONIC SHIFT ON THE FLY (ESOF) ONLY
ISSUE:
Some vehicles may exhibit inadvertent 4X4 Hi or Low shift events, 4X4 and/or Low Range indicator flashing or solid or vehicle stuck in 4L after uncommanded shift. This may be caused by the 4X4 shift motor.
ACTION:
Install a YL1Z-7G360-AA shift motor on vehicles built before 12/99. The YL1Z-7G360-AA shift motor with a grey contact plate cover replaces the prior design F75Z-7G360-AA motor with a blue contact plate cover. Grey cover shift motors contain improved sense plate material and shift motor terminal upgrade. For vehicles already equipped with the latest style shift motor, refer to the following Service Procedure for details.
