i have a 68 f250 highboy.4x4.390..detroit lockers with a busted rear driverside axle..ive found a dana 60 rear end from a mid 80s van.will the rear axle work?and would it be easier to replace the whole rear end?
Well if you have an actual locker and not the dana limited slip than axle splines could have been changed by now. You need to pull the axle and count the splines. The 16 spline is such a bad axle that you can get them for free. Post an ad on here or go over to pirate4x4 and check there.
