Talked to Service Advisor About Heated Seats
Old Mar 6, 2009 | 01:45 PM
Immortal_Ben's Avatar
Immortal_Ben
I showed her pics of my burnt seats and she said the same thing happened to her FUSION! Hers was fixed under warranty, but she came close to having to go to the doctor because the thing decided to burn up while she was sitting it the seat.
Anywhoo... no there is no recall or TSB for this... Im sure you guys already know, but maybe if we all go in and grumble about it.... who knows.
Old Mar 6, 2009 | 02:26 PM
ReAX's Avatar
ReAX
Did the seat catch fire or just the element got hot and tried to catch it on fire? I'm not to sure, but I believe that if the element tried to get hotter than intented (shorted out), then it would draw more amperage and should pop a fuse. If ford failed to fuse them, there might be grounds for a class action suit. Perhaps if you can get enough people to talk to ford and mention class action law suits they'd replace your seat cover, foam and element.
I wonder if I should go out and put a small fuse under each seat?
Old Mar 6, 2009 | 02:39 PM
dunerunner25's Avatar
dunerunner25
I was wondering the same thing.... How did it burn her did it instantly get so hot that she couldn't get up or turn it off??? WTF!!!
Old Mar 6, 2009 | 03:07 PM
1 Excursion camper's Avatar
1 Excursion camper
Yep, some of the Chrysler Jeep and Dodge vehicles have that problem. some of them are covered under a recall. you can press them (Ford not the dealer) a little harder they may take care of it for you!
Old Mar 6, 2009 | 06:05 PM
Immortal_Ben
She didnt specifically say what happened, but I THINK she was saying that it felt like there was a sharp spike in the temperature of the seat materials. I guess it tried to catch the seat on fire. I would assume the are flame resistant materials from the looks of my foam.
I dont think forum rules allow for talk about class action lawsuits, so I would just encourage anyone with the problem to contact Ford about it. I am going to look for Ford corporate contact info and send a complaint.
I dont know if a fuse in the line would prevent anything from happening. I dont really know if there is an intended top temperature... one would think there is, but someone with knowledge in this area would have to chime in.
Old Mar 6, 2009 | 07:19 PM
ReAX's Avatar
ReAX
It's not so much for top temperature, but top wattage. The element should produce XXX watts of heat I guess. If for some reason it shorts out and the resistance drops down lower, it may produce more heat by drawing more amps. If a fuse limits the amperage to 10A @12v so 120watts, or 15A for 160watts. It's just an idea, I'm not sure if heating elements work that way, but if it will stop a case of the red **** it's worth a try.
Old Mar 6, 2009 | 07:42 PM
Immortal_Ben
Aye, I too wouldnt like to have the hot cross buns.
Snowking
Jan 23, 2008 08:01 PM
msgtg
West Virginia Chapter
Jul 17, 2007 11:05 PM
rmalottwtes30
55
Aug 24, 2006 12:43 PM
natebaker
1983 - 2012 Ranger & B-Series
16
May 26, 2006 05:08 PM
King Triton
24
Apr 10, 2005 11:20 PM
