1993 2.3 Ranger power loss
Old Mar 4, 2009 | 07:17 PM
jimgov's Avatar
jimgov
I have a 1993 ranger with a 2.3L 5 spd - while driving it seems to lose power / stalls for a second or so and like pops and restarts. Never stop running for long - don't even slows much.
Any Ideas??
Thanks
Jim
Old Mar 5, 2009 | 07:03 AM
customstringer's Avatar
customstringer
Welcome to FTE. I think to get some replies you are going to need to provide more information as the symptoms you describe could be fuel/air/ignition/sensor related. How many miles on the truck? What maintenance has been done and when, plugs, wires, fuel filter, air filter. What speed and conditions are present when the stall occurs. Has it triggered the MIL and have any codes been pulled. What I've said here is the tip of the iceberg as there are others with much more diagnostic experience. Provide more information and you might get some responses. Good luck.
Old Mar 5, 2009 | 09:32 AM
BSmitty's Avatar
BSmitty
Yep, more info will help! Customstringer is dead on with his questions, answers to those are a great place to start. It could be fuel or ignition related.
Old Mar 5, 2009 | 05:49 PM
jimgov's Avatar
jimgov
New to me truck - been sitting about a year - would not start when I bought it - was told fuel pump / filter was replaced to try to get it going - I replaced fuse for fuel pump then started right up. Had check engine light - code was 311 EGR If I plug straight vacuum to the EGR - it opens up and no light (passed Emmisions test that way- idled rough though) thinking it may be the PFE switch Have spare and planning to replace that - could that be causing it? truck has about 125000 miles - runs great other wise - just like someone shuts the key off then right back on.
Also planning complete tune up and timing belt as I don't know when done last.
Just wondering if this was a common issue?
Thanks! -This sight has help out quite a bit on my Fords! Keep em coming!
Old Mar 5, 2009 | 07:06 PM
michigan66's Avatar
michigan66
While you may be putting timing belt #2 in it, its time for #3, so you're 'way overdue. I'd still check fuel pressure.
Choptopjimmy
Sep 30, 2014 11:58 AM
TransplantX
4 Cylinder Engines
Jun 20, 2013 12:41 AM
Ford_or_bust
Jul 3, 2007 08:14 PM
Kijutsu
Feb 16, 2006 11:21 PM
