'94 Ranger extended cab rear window - what fits?
Old Mar 4, 2009 | 05:36 PM
yagerzzz's Avatar
yagerzzz
Hi. I have a '94 extended cab with a solid rear window. I would like to replace it with a slider. I know the standard cabs of that era had a smaller rear window. What about newer Rangers? I noticed the newer standard cabs look to have a larger rear window. Anyone know if those would happen to fit my '94 extended cab? If so, what year did they start making the rear window larger on the standard cabs?
Thanks!
Old Mar 4, 2009 | 05:51 PM
85e150's Avatar
85e150
I had this experience with my '86. They brought out a slider for a standard cab and suggested I could just caulk up the gaps....
I ended up buying a Ford Slider, as there was no aftermarket for the bolt-in type window.
You can check the FTE parts guy here and see if you can get a factory window for a decent price.
It's quite a job to pull one as all the trim has to come off. Be sure it's a hot day and park the truck in the direct sun to make it more enjoyable.
Also, Numberdummy can check to see when the part number for standard cab became the same as Supercab.....
Good luck.
Skip1970
Jan 31, 2016 03:08 PM
69issofine
Nov 3, 2015 10:22 AM
F-150 MP
2004 - 2008 F150
Jul 30, 2015 08:38 PM
fairlaniac
Dec 7, 2007 12:32 AM
jjanssen
May 9, 2007 11:59 PM
