Hey guys,Neither the front nor rear windshield washers will spray on the Ex I picked up last weekend. I originally thought it was just low on fluid but that's not the case. I don't hear the motor when I push the button for either one. I didn't get a manual with the truck and there is no diagram on the fusebox cover. Could someone please let me know which fuse to check, or if you could scan a fuse layout from your manual and post it for all who need it, that would be even better. Also, I didn't see a wiper fluid tank anywhere in back, I assumed it would be in the jack compartment. Does it pump all the way from the front, or did I miss it somewhere? Thanks in advance for any help.
I tried to just post the links, but mine don't seem to be working.
fuse 21- 25 amp rear wiper motor
33- 15 amp front wiper
48- 10 amp rear wiper motor
106-30amp front wiper main
I would try these first, and if no luck, it is good to check all the fuses. They are known to not label all the functions from fuses. I know it is a pita, trust me.
wiper fluid tank is in the front only, and rear hose runs on the inside. Some have had no washer on rear and several areas where the joints come off. In front passenger side, lift up the bottom pc when you open door, you will see hose. Other spot is in back in top head liner.
