heater core hose removal???
Old Jan 27, 2009 | 04:44 PM
zed326's Avatar
zed326
how do you get the heater core lines off the core they look like some kind of quick disconnect? but there is not much room in there to work
Old Jan 27, 2009 | 07:31 PM
vettman80's Avatar
vettman80
vettman80
when i replaced the heater core on my 99 i used a hacksaw and cut the heater core lines inside the heater box then pulled the lines towards the engine and through the firewall then you will find that the hoses are a quick disconnect you have to squeeze the plastic ends on the hoses and twist the hose and pull then they will come apart good luck
Old Jan 27, 2009 | 07:37 PM
Tommy_Mills's Avatar
Tommy_Mills
If you take an air nozel to blow as much crap out of the way as you can, then soak them with WD-40 or PB blaster to lube them up they should come. Push in on them as much as you can before trying to press the plastic tabs in to release them. Dont forget about a sawall with a hack saw blade though, but that gets kinda messy.
Old Jan 28, 2009 | 04:14 PM
zed326's Avatar
zed326
i dont have a problem with it leaking it is pluged up and i need to blow it out some and get it flowing again, the blend door work s as does all the switchs...it just seems lik it is not flowing through it. when i rev it up the heat comes out warm but then fades away when i lower the rpms??????? i dont know what else to try
Ibuildmyown
Nov 28, 2015 05:49 AM
Suprawill1
Escape & Escape Hybrid
Jan 23, 2014 12:32 PM
brandon olson
1997 - 2003 F150
13
Dec 30, 2013 08:02 AM
noclue66
Aerostar
Jan 13, 2005 11:52 AM
tkbowman
Feb 12, 2001 06:34 PM
