EGT Readings on Banks Stinger Kit
Old Jan 20, 2009 | 02:32 PM
jkidd_39's Avatar
jkidd_39
I have a 2001 f-250 CCSB 2wd w/ 135k miles
It has the banks Stinger Kit. IC Pipes, 40 HP Chip, Banks Wastegate, WW, Transmission line booster, and Banks Transmission Cooler.
I don't believe it has the Banks IC tho. We bought the truck w/ it so i'm not sure, and I do not have the truck to check.
My question is how hot should the EGT's reach? I run about 500-600 down the highway at 75-80 mph. And up big hills w/ 14000lbs GTW I stay right at 900 Fahrenheit when I'm going up big hills. Does this sound like the proper temps? I do not know if the EGT is pre-turbo like it should be so I wanted to double check to make sure I'm not over heating anything.
Thanks alot guys.
Old Jan 20, 2009 | 02:39 PM
Adam0331's Avatar
Adam0331
Your temps sound good to me. Is that pre or post turbo?
Old Jan 20, 2009 | 03:26 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
sounds good if its pre turbo... if its post turbo, i would put in the manifold ASAP towing 7 tons
Old Jan 20, 2009 | 03:57 PM
BENG0924's Avatar
BENG0924
You need to see where the EGT probe is I believe Banks is the company who reccomends post turbos (downpipe). If it is post turbo it is really hard to say as they about the temps as the vary but 900 could be pushing it, or it could be fine.
Old Jan 20, 2009 | 04:04 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Those temps are great. I wish my temps were that low. On flat land I run 750* doing 77 MPH. Climbing hills with that much weight I can hit 1200*.
Old Jan 20, 2009 | 04:49 PM
Pocket's Avatar
Pocket
With a temp reading like that, I'm positive that probe is in the downpipe.
Need to move that probe to the manifold or up-pipe, especially if you're towing like that regularly.
Old Jan 20, 2009 | 07:59 PM
CSIPSD's Avatar
CSIPSD
Move your probe to the up pipes or manifold and use 1250 as your extended time limit. You can go over that for short times but that is your red line otherwise.
