DP Tuner ?
Old Jan 19, 2009 | 08:04 PM
mblanken881's Avatar
mblanken881
DP Tuner ?
On the DP Tuner website they recommend having an intake first. What options are there for the intake?
Thanks, Mike.
Old Jan 19, 2009 | 08:07 PM
megawatt00's Avatar
megawatt00
Inexpensive and good would be the 6637
Old Jan 19, 2009 | 08:09 PM
mblanken881
Oh, thats all he's referring to. Thats good because I already have that done!! Looks like I'll be looking into a set of gauges and then the tuner!!
Old Jan 19, 2009 | 08:16 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Don't forget exhaust and Valve Body, after the gauges.
Old Jan 19, 2009 | 10:44 PM
00Dave's Avatar
00Dave
I did the 6637 and Waler BTM in prep for the dp. Then I ordered dipricol gauges and dp from Dennis @ ITP. I am very satisfied with my gauges, just my 2 cents. Didn't know if you are looking for some or already picked out what you want. Good luck!
Old Jan 20, 2009 | 07:49 AM
mblanken881
Yeah, I'm still looking into what gauges I want. I was looking at the Isspros with the white background. What valve body do I get? My 4" MBRP exhaust is sitting no the shelf waiting to be installed this weekend.
Old Jan 20, 2009 | 07:55 AM
Ponyboychris's Avatar
Ponyboychris
Can't help with the valve body recommendation but I have a write-up on my 4" exhaust if you like them. Just some gotchas to look for. PM if you are interested.
Old Jan 20, 2009 | 08:11 AM
miller_feed
There are 3 that people in here like. I have the BTS-VB and installed it myself. Some have the JW-VB and install it themselves. Some like to do the TRANSGO kit, where you do the work on the VB yourself. Either would be fine.
Old Jan 20, 2009 | 09:53 AM
jdecker88's Avatar
jdecker88
You can do the transgo your self if you have mild mechanical skills if not a BTS or John woods VB before you get the chip. Though if you get the JW you can get the DP first and not have to get additional tunning.
Old Jan 20, 2009 | 10:11 AM
miller_feed
JD is right about the JW. If you go with the BTS-VB, you will need to tell Jody and Brian that you are getting the other. They will tune for the other.
Old Jan 20, 2009 | 11:09 AM
just another truck's Avatar
just another truck
Justin.. do I see foil under that hood???
Old Jan 20, 2009 | 11:19 AM
jdecker88's Avatar
jdecker88
Very old picture I don't have another good one of the filter.
Old Jan 20, 2009 | 11:21 AM
just another truck
I had thought you had painted you IC pipes.. but when I saw the foil.. thought I was loosing it..
Old Jan 20, 2009 | 11:22 AM
HKusp's Avatar
HKusp
According to Gene, the foil is actually a benefit to intake air charge temperature.
Old Jan 20, 2009 | 11:31 AM
just another truck
I remember that thread.. I thought by the end of it.. most thought the air wasnt there long enough to change temp..Also.. The foil was on the hot side, instead of the cool side where we all thought would make more sense??? It was a while ago..
