Are these axles close enough to switch. HELP
Old Dec 3, 2008 | 09:23 PM
hootersonwheels's Avatar
hootersonwheels
Exclamation Are these axles close enough to switch. HELP
Long story short, Big ditches, fast speeds, bent axel tube(assembly).
I need a new rear axle assembly cause nobody will sell just one side. The problem is that I can't find one within 300 miles that doesn't have the same tag.
I went to a junk yard today and found one close but not exact. Everthing appears to be the same except the new one has front and rear shock mount brackets and the brake lines might be a bit off.
My tag is S862B the one I found is S862F.
Will the F work in my truck?
Oh ya where should I look for a front leaf spring hanger?
98 F150 4.6 4X4 3.55 gears
Old Dec 3, 2008 | 10:57 PM
85e150's Avatar
85e150
My secret decoder ring, the source of which I can't reveal, says:
S862 B: F150, '97-'99, 3.55, 8.8 ring, non-limited slip.
S862 F: F150, '00-'01, all else the same.
You've noted the visible differences, if you can work around those, you have a winner methinks.
Good lucksky
Old Dec 4, 2008 | 12:13 PM
Lazy K's Avatar
Lazy K
Good lucksky:-drink
Nice post as always.
For spring hanger (perch) try stengelbros.com and good luck.
Old Dec 7, 2008 | 02:05 AM
hootersonwheels
Well I got everything put back together and it went pretty smooth. UNTIL, I went to put the tires back on and the lugs weren't the same size. I would have just waited till the next day and bought new nuts, but I had a trip to make the next morning. To make it worse the lugs off the old axle wouldn't go in the new rotor. So we drained the diffy and put the old axles back in with correct lugs. It was a long ways to go back and do again just cause off one little problem. But thank you for the help.
NJFORD
Apr 7, 2009 12:48 PM
hootersonwheels
1997 - 2003 F150
Dec 3, 2008 10:49 PM
bud_neumann
1997 - 2003 F150
Jul 22, 2008 08:13 PM
zeaga
Jun 19, 2007 04:45 PM
