rear tag numbers
Old Apr 2, 2009 | 02:55 PM
NJFORD's Avatar
NJFORD
rear tag numbers
Can anyone tell me what rear i have from the tag #s-tag reads s862b 55 88 sf27-it is starting to make a grinding noise and i have to replace it or do a rebuild -is a rebuild difficult or can a pretty good shade tree mechanic handle it --97 f 150 4x4 -Thanks
Old Apr 2, 2009 | 04:03 PM
rclarke's Avatar
rclarke
s862b is the model of the differential to find the right parts list. The 3 that goes with the 55 is under the bolt holding the tag on. The ratio is 3.55. If there is an L between the 3 and 55 it is a Traction Lock. 88 is the size of the ring gear (8.8 inches). sf27 is build date information.
Old Apr 3, 2009 | 12:12 AM
85e150's Avatar
85e150
S862-B = '97-9 F 150, 8.8, 3.55 ratio, non-limited slip.
SF27 does not work as a date code per my decoder ring, as the "S" should be a number, perhaps an "8"???
Rebuild it yourself? You have a lift, or do you like working in the dirt under the truck? Got a dial indicator? Inch-lb torque wrench? Time to do it more than once if you fubar?
I watched a Ford mechanic do an 8" on the bench and decided it's best left to those who've done more than one, if you want it to last and not howl....jmo, ymmv.
Old Apr 3, 2009 | 09:56 AM
NJFORD's Avatar
NJFORD
Thanks for the info -the s is a 6 i cleaned the tag better-I think i will have it done by a mechanic -dont want to do it more than once.
Old Apr 3, 2009 | 11:39 AM
85e150's Avatar
85e150
6F27:
6 as in 1996
F as in June, the 6th month, using the 6th letter to designate. (Note "I" and "O" are not used.)
27 as in the 27th day of the month.
June 27, 1996 in other words, early production methinks.
Good luck on the rebuild.
Old Apr 7, 2009 | 12:48 PM
bacwudzme's Avatar
bacwudzme
My friend has a 03 F-150 5.4 auto 4x4 with 3.55 with non limited slip. the offroad shop near our house has a 07 f-150 5.4 auto 4x4 limited slip rearend unit. now the question is the 07 axle was 9.75 it had 3.73 gears the custemer replaced that with a truetrac and 4.56s. now my friends rear axle is 9.75 are they inter-changeable? will the unit just bolt into the 03? the offroad shop said it would or should. it is just the "pig" does it matter that it had 3.73 and going to be bolted to 3.55s? and will axle shafts going to be the right lengh for the clips? All constuctive input is appreciated. Thanks
3twinridges
Mar 26, 2017 08:56 PM
deezdrama
Sep 1, 2016 08:16 PM
ncheavymetal
North Carolina Chapter
Jun 29, 2016 08:34 AM
82fordowner
Jun 21, 2016 12:29 PM
silverz98
May 23, 2007 12:18 PM
