i want to hook mine up to a sled once, just to see what it would do..... although i already know what would happen if i did it right now, i need to get ladder bars on the rear.
im gonna do wat diesel jim did i think. take 3 point hitch arms cut and weld them up longer then make brackets for mounting. i think he did his for 60 some bucks
Joe as long as you dont romp on it youll be fine I almost pulled mine but didnt for the saem reason. After watching John pull its not bad if you dont get in it to hard. I think im going to pull this summer. Sure i wont win but who cares.
lol, you havnt seen how bad my truck twists the rear axle.... i can raise the rear bumper about 10-12 inches just by mashing the throttle from a standstill with no load on the truck. the vibration in the cab will rattle the trim screws loose to the point that they fall out if i dont check them frequently.
So thats why my trim screws keep coming loose...lol. I cant even do a burnout, it just hops. Id like to put some of those redneck ladder bars on mine someday. Only way I can do anything close to a burnout is tach it up and dump the clutch in third gear from about a 20mph rolling start on a wet road.
I havent got the nerve to hook mine to a sled yet. Its my only form of daily transportation, and the wife would kill me if I tore it up pullin a sled.
mine is my transportation to. as long as you be careful and listen anf feel for everything. i had a littla hop at first let off a little to smooth it out then got into it hard. i didnt break a thing and my drive shafts still have no play. come on guys lets get some more pics on here. lol
actually it depends on the sled and the track. when i pulled at goodells it would have been best to pull in lo 3rd, but when i pulled at the armada fair later in the year i was pullin against the big trucks (like john klein's dodge, and joe servo's ford w/ cummins and the chevy dirty hooker,) lo 2nd was the best gear to pull in. but my truck has 3.55 gears so if i had 4.10's i probably would use high 1st or low 3rd and never use low 2nd. another factor is if the track is sticky you wanna be in a lower gear while if it is dry it seems to work better to get your tires spinning faster in a higher gear.
if you do get ladder bars my tip of advice is make sure they are welded on and not bolted cuz the axle will still twist if bolted.
