2000 7.3 missing cylinder 5 error
Old 11-26-2008, 06:37 PM
BATTLIN_BLAZES's Avatar
BATTLIN_BLAZES
BATTLIN_BLAZES is offline
just did a ton of work on it seemed 110% fine stopped and the owner stopped and fueled at at a local fuel station known for crap fuel!!! it has since started missing bad and the computer is showing cylinder 5 hi to low open error. work that was done was glow plugs changed all, oil change, fuel filter, batteries replaced. Is it possible the fuel is crap, thinking maybe #5 injector wire is off or injector is bad? any ideas? not sure what the hi to low open error is telling me? thanks.
Old 11-26-2008, 06:51 PM
BATTLIN_BLAZES
also which one is #5?
I'm thinking after reading some previous post maybe a loose injector plug being everything was just apart for glow plugs maybe its worked itself loose while driving?
Old 11-26-2008, 06:56 PM
ccg711's Avatar
ccg711
ccg711 is offline
what computer are you using to scan. If capable do an injector buzz test. Also use a multimeter and ohm out the valve cover harness to check it electrically. Just do a search on this forum, the instructions will pop-up. What's the specific error code number?
Chad
Old 11-26-2008, 07:45 PM
F350-6's Avatar
F350-6
F350-6 is offline
Is it a high side or low side error? Which code did you pull? You could try a buzz test, or simply ohming the injectors to see if there's a problem. you might also check the wiring between the valve cover and IDM where it crosses the drivers side valve cover for any chaffing issues.
If you've got a code pulled Click Me Look at section 4a and scroll all the way down to diagnostic trouble code description. That will give you a link to the diagnostic tree so you can start checking things out.
Old 11-26-2008, 08:40 PM
BATTLIN_BLAZES
the test were preformed with a snap-on solus scanner and here are the codes I am getting:
p605 internal controle module
p1670 EF feedback signal not detected
cylinder contribution test:
p0275cylinder 5 balance fault
injector buzz test:
p1275 cyl 5 high to low sde open
At this point knowing it was just apart I'm assuming the obvious is to tear back into it and check the number 5 injector, wires and connections sound reasonable? I'm thinking maybe something is loose I see quite a few post on a kit to secure these injector connections. any of these codes screaming anything different? thanks again the advice is appreciated
Old 11-26-2008, 09:01 PM
F350-6's Avatar
F350-6
F350-6 is offline
injector buzz test:
I somehow managed to knock the connector off the #5 injector while putting the valve cover back on after re-torquing the injectors and rocker arms on my wife's truck. Don't ask me how, but I'm good at things like that.
It threw the CEL and set a P1316 code. If you clear everything, does the 1670 come back? If so, I'd start checking those wires between the IDM and valve cover.
Old 11-26-2008, 09:34 PM
BATTLIN_BLAZES
thanks for the ideas this is a project my 16 year old took on for his boss he is in a vocational school mechanics class so the help is greatly appreciated and it will be some more great experience for him to track this down. I wasn't real excited when they ask him to do this a little nervous actually but know I'm confident he will find it and impressed with what he has learned. so many thanks for helping out a youngster with a ford truck passion.
DieselDenny
6.4L Power Stroke Diesel
01-31-2017 08:51 AM
04150
2004 - 2008 F150
02-03-2016 07:24 PM
bamaf150
2004 - 2008 F150
09-11-2013 03:03 AM
paulcalif
1999 to 2016 Super Duty
07-18-2010 10:09 PM
mikeast
03-27-2009 11:19 AM
Quick Reply: 2000 7.3 missing cylinder 5 error
