block compatablity
Old Nov 18, 2008 | 02:56 PM
rapterman101's Avatar
rapterman101
block compatablity
302 and 351w, are they same block famly or am i going to have to change all the font brackets and pulleys if i swap 351 for 302
Old Nov 18, 2008 | 03:26 PM
MBDiagMan's Avatar
MBDiagMan
They are the same family and mostly it will bolt up. If you are putting a late block in an early chassis you won't have a drilled and tapped hole for clutch linkage.
The timing cover and water pump will fit, but the bolt holes in the head are in a different location due to the increased deck height.
If you are not changing a complete engine, you will have to come up with a different intake manifold and distributor.
If you are not putting it in a truck chassis you might have hood clearance issues and although it is only a slight difference, you might have exhaust pipe fit up issues.
Hope this helps.
bmacky14
Nov 24, 2009 11:35 PM
letsgomuddin85
22
Mar 21, 2009 10:41 PM
briank
15
Oct 18, 2008 11:07 PM
joeKyTN
13
Mar 10, 2008 01:26 PM
Crazy Canuck
Apr 4, 2003 04:23 PM
