So I've been out hunting Deer all week, and 2 days ago I was doing some MAJOR 4 wheeling, doing a climb up a rocky road, in 4 wheel drive most of the way up a very VERY steep road. Regular cruising thru the woods I normally run about 150-160* temps with the Napa Ultra cool......but this very long climb up this road gradually got my temps climbing up. I'm not sure if it was just the sheer angle of the road that made the pump too weak to have it flowing........or just the fact it was being worked hard? I pulled over once I hit 200* It probably would've climbed even higher.....but I wasn't gonna chance it! I'm running Valvoline synthetic Mercon V fluid....which is only like 2 months old. Nothing smells burnt so I'm not worried about my fluids......I'm just curious if you guys know enough about the inner pump on the 4R100 to know if severe angles like that affect the flow? Sorry for the long winded post!
I've had this happen pulling steep grades hunting last year before the Tru-cool, but nothing since. Hope this helps, and how is the hunting going? Starts Sept 1st here, and can't wait. Been scouting and seeing some real nice book bucks this summer myself!
i hit 240* going up Ice house road to loon lake @ the rubicon pulling a 8k load. it peaked @ that temp, when i got there checked the fluid and didnt smell burnt at all. ran great the rest of the 530 mile trip home.
No, the clutches were not slipping. If they were the fluid would be black and the trans would be history.
The torque converter was slipping. It is designed to slip, that's how a torque converter works. Under heavy load, such as MAJOR four wheeling, it slips a lot and generates a lot of heat.
The pump does not have a problem with angles. If it did you would know right away. The first thing that happens when the pump sucks air is that the clutches release and you're in neutral. Clutches can't stay applied without pressure.
200F is nothing to worry about. You're not even close to a temperature to worry about. If you want it cooler, get more trans cooling. If your truck doesn't have a trans cooler in the radiator that would be a HUGE improvement in low speed trans cooling. A 6.0L cooler will help a lot, too. In my opinion it's a waste of money to do either if you are only seeing 200F. That's not hot at all.
The Napa Ultra cool is basically the exact same thing as the Tru-Cool.......I have no problems under "normal" conditions even towing up grades. Hunting was slow at first, but its picked up the last couple days, I've put a stalk on several nice bucks, but now I'm off camping for the weekend.....the hunt runs until sept 11th....plenty of time
that's HOT! That is wayyy too hot for only towing 8k.....time for some upgrades I'd say!
Thanks Mark....was hoping you'd chime in here! I didn't think 200* was a problem, but I pulled over so I never reached the magic 210* mark......under "normal" conditions the highest temps I've seen yet even towing are 180*. My truck is a 2000 so I don't think I have any type of cooling thru the trans, but I did add the Ultra Cool from Napa, ran it in series with the stock cooler.....seems to do a great job, but that climb the other day offroading was about 30 straight minutes before I saw those temps.....I wonder what the same scenario temp-wise would be with a 6.0 cooler....Hmmmm........anyways, thanks to all who responded! Reps for all of ya
My old '99 PSD truck saw 215 degrees pulling my 5'ver up the east entrance of Yellowstone thru a construction zone. It only had the stock cooler and no OTW radiator cooler. Crawling at 10 mph, only one lane, dirt road, construction equipment everywhere and no pullouts. Not fun at all. Tranny wasn't slipping but I had my one eye glued to the gauge the entire 10 miles. Not fun but the truck survived. I did loose the front t/c seal though a few days later on that same trip. Figured that the high temps must of killed it.
