no boost
Old Aug 28, 2008 | 08:11 PM
donewithsparkplugs's Avatar
donewithsparkplugs
no boost
I have a problem with no boost. It had a code p1247. While driving the harder you would push it the more exhaust sounded like it was fighting to get out. So after looking at all the plumbing intake to tail pipe with no problems found No holes in any of the tubes or rubber connectors and no flat pipes. Pulled the turbo( leaking lots of oil in to the intake and has a beat up charge wheel any ways) and found the back pressure valve stuck way past open. That closes off the port. Has this happened to anyone here.
SO THE QUESTION IS ABOUT THE TURBO BASE.
Has anyone had any problems with theirs with the controls, sol, for the back pressure valve.
I would have used the search but almost sure that it isnt called a back pressure valve.
2000 7.3 F450 super duty 6 spd
Old Aug 28, 2008 | 08:54 PM
F350-6's Avatar
F350-6
Almost sure was almost right. It's the EBPV (exhaust back pressure valve). You could wire the valve, then gut the internals in the pedestal if you don't want to mess with it again. You could also spend the money and buy a Non-EBPV pedestal if you don't want the DIY version.
Here's a short video someone else posted a link to a while back. It shows you how to gut the pedestal yourself. Video of Gut and Plug - Photobucket - Video and Image Hosting
I'd recommend loc-tite on the bolt instead of the teflon tape.
Old Aug 28, 2008 | 09:06 PM
donewithsparkplugs
Ok as for the diy My chevy k 1500 has some air bags from a crown vic aired up from a compressor from a buick.
Thank you for the fast answer.
Old Aug 28, 2008 | 09:14 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If you want to get rid of the EBPV you can purchase a new pedestal with it deleted, and a turbine outlet plate with the valve deleted.
460 style
15
Aug 31, 2010 02:35 PM
psdendurance
Jun 16, 2008 06:03 PM
ROKNZRX
Jul 6, 2007 09:56 AM
chadjones99
Apr 7, 2006 10:16 AM
