keeping wide white walls clean
Old Jul 19, 2008 | 10:43 PM
snipa's Avatar
snipa
Any tips from any of the experts out here on this subject?
thanks
Old Jul 20, 2008 | 08:02 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Westley's Bleach White tire cleaner was the best seller back in the '60's.
Old Jul 20, 2008 | 08:21 AM
xfordman's Avatar
xfordman
A 'Mr. Clean' product for the home called 'Magic Eraser'. Ask your wife, she probably has one, THEY WILL MAKE EM LOOK NEW....Rod
Old Jul 20, 2008 | 12:53 PM
LEckart's Avatar
LEckart
Back in the day (50's/60's) we always used Ajax or Comet to scrub them clean, with a small stiff bristle brush.
Old Jul 20, 2008 | 12:59 PM
birdman1's Avatar
birdman1
Yep that right, Comet was the choice for great white walls. The parts stores use to have the slimmy stuff that the tile dealerships had, that seemed to work so good. With the lack of whitewalls nowadays, Comet may be all you can find.
Mike
Old Jul 20, 2008 | 03:33 PM
mblayton's Avatar
mblayton
Bleach white does an amazing job. Up in Canada I have also used SOS pads, they are very fine wire wool with a soapy solution in it, get it wet and scrub.
Old Jul 20, 2008 | 06:26 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
If you use Westley's Bleach White tire cleaner,which is preferred,there is usually no hard scrubbing necessary.Often,the dirt just rolls right off as you spray.Using Comet,Ajax or the like,and scrubbing with either steel wool or a stiff wire brush,while necessary for severely dirty or neglected tires,abrades them slightly,opening up the rubber and causing it to collect more dirt in the future.Steve.
Old Jul 20, 2008 | 08:37 PM
2many56s's Avatar
2many56s
Westley's sprayed on then I scrub with green scotchbrite pad which they sell to clean pans with. I scrub, then in one pass, I take a clean rag and wipe off the residue, pressing hard and stopping to turn the rag to a clean spot every 6in or so. Always keeps mine looking like new. The truck can be dirty, but the 'walls got to have the shine!
Bill W
Arizona Chapter
42
Sep 10, 2010 02:31 PM
thehammer322
Computer Chips & Tuners
Nov 16, 2003 11:21 AM
Vampiro
Aug 23, 2002 11:05 PM
ludis
Nov 3, 2001 10:59 PM
