Got my NEW lift!!!! Set up pix...
And yes, after the lift was done I actually spent some quality time with my boys!
So, other than a few VAGUE parts i- the instructions (air hook-up), it was fairly straight forward. Especially as I took into account the previous tips on cable routing which helped - Thanks!!
As for the air hook-up, the instructions didn't show the air button or where the air hose connects, but after some CSI work we where able to find the button and figure it out.
As I`ve said - I had a friend who had done a few - here`s a picture of a guy (and his girl...) you want to have around when working on you lift, your car, your shop.... :thumbup:
¸Of course once we had it all together, the posts straightened plumb (had to move a couple posts a bit with a 2x4 and hammer) and the hydraulics connected, we noticed the entire unit was ****-eyed in the shop.
It was easily remedied with the caster kit, so, although I had said in another post maybe save your money here as you may never move your lift, I take it back, because even if you have to move it a couple inches you'll need the casters.
I was able to put them together, connect them, lower the lift all the way until it was on the big wheels and easily move it square in the shop, then remove them again. I made a rack on the wall beside the lift to get them up and out of the way when not in use.
Gotta say - I`m thrilled. Everyone who`s seen it, again a couple guys with experience, thinks it`s HEAVY DUTY. It`s so heavy duty in fact, that the oil-drip trays are made of heavy stainless...
...these could easily have been made of plastic to save money and weight...or even aluminum.
The only thing I think I might change is how the jack x-bar (youngest is standing on it) moves on the ramps. The roller jack - of course - has rollers that make it glide along the ramps, but the x-bar justs rests metal on metal, which not only takes all the paint off both surfaces, it tends to bind. Maybe once all the paint is scraped off it`ll be easier to move
...Or I`ll fab up some rollers.
So, THANKS 1st to the guys at BendPak, especially Jeff who initially sold me on this lift and Bruce at Babco Sales who got the unit routed and shipped to me. Everything these guys said thus far has been dead-on and that counts for a lot.:beer:
I`ll be running cars up and down the new lift in the coming weeks, so I`ll update it then. The only problem I have now is: which car goes on first - The Galaxie to do the power steering... Or the 46 Merc to weld a beam...or...
Oh - and here's the great wife (with her race 240Z) tht puts up with it all!
I noticed today - you can change the ramps and blocks around and enter lift from either end - ya-hoo!!
As for height, I'm 6'2" and in my 11 foot shop I can easily stand under the Galaxie on the lift with about 6" to spare to the ceiling. As well, at first I had the ramps set to rise with the lift, but then they were right at Forehead height
They are easily removed, so off they came!I'll post some photo's right away here.
Anyways, the Galaxie Steering Box puked 2 summers ago and I was using "arm-strong" steering ever since ( I either had a project over the pit, or was building the shop). With the lift, I had the steering box out and replaced in a couple hours. While it was up there, I changed the oil and semi-fixed the e-brake too, also not working for a while (still needs parts though).
The other cool thing I hadn't thought of, is that I can approach from either side. My shop has doors at both ends with a driveway on one end and a lane on the other - so it makes it nice to be able to pull through, or bring it in the easiest way.
dint see no lift ...
