6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L Internals and Construction?
Old Feb 20, 2008 | 07:10 PM
SID297's Avatar
SID297
I was wondering if anyone had much experiance with the 6.4's internals. Were the head gaskets and head bolts upgraded from those used in the 6.0 (which had a habit of lifting heads and eating gaskets)? What seems to be the hp limit on the rods? I noticed that it uses powdered metal construction instead of traditional drop forging. What are the hp limits of the injectors?
Any other info would be helpful, thanks.
Old Feb 21, 2008 | 01:53 PM
diesel_dan's Avatar
diesel_dan
Take a look at the Tuned Dyno Numbers thread in this section -- impressive indeed...
Old Feb 21, 2008 | 07:19 PM
SID297's Avatar
SID297
I've been posting in there, but I was hoping for some pics or specific numbers.
Old Feb 22, 2008 | 11:51 AM
SANDDEMON08's Avatar
SANDDEMON08
The small block is basicaly the same as the 6.oh, but they have fixed the previous oil starving issues the 6.oh had. The connecting rods are larger, stronger rods that have an increased rod bearing diameter. They made the head studs larger then previously and added a few to better secure the heads down. The heads are a completly diffrent design, the piston bowl is design to optimize the high-cylinder pressures delivered by the high-pressure fuel system. The higher pressures provide more efficient combustion, delivering increased power form the comon rail fuel system.
Old Feb 22, 2008 | 02:33 PM
Momorris's Avatar
Momorris
Does this mean the 6.4 has headstuds or do they still have the TTY bolts like the 6.0?
Old Feb 22, 2008 | 06:01 PM
SID297's Avatar
SID297
That would be a good piece of info to have. I'd like to see some pics of the engine being built.
Old Feb 22, 2008 | 06:29 PM
rollerstud98's Avatar
rollerstud98
no studs from the factory from what i've understood so far
Old Feb 22, 2008 | 06:35 PM
SID297's Avatar
SID297
I wouldn't think so, but the bolts must have been improved. The 6.4 runs enough boost stock to lift the heads on a 6.0.
Dirtboy953b
Dec 15, 2014 08:47 PM
Randy367
1983 - 2012 Ranger & B-Series
Dec 10, 2014 01:07 PM
raptor2005
Sep 4, 2012 10:13 AM
HADaChevy
Mar 1, 2009 07:58 PM
John Kiernan
Mar 20, 2008 08:11 PM
