98 ranger 3.0 no 4x4..... 4X4 lightS blinking 4 times
Old Feb 13, 2008 | 02:46 PM
huggyjd's Avatar
huggyjd
Just bought this 98 Ranger 3 days ago. The guy told me everything worked! What he failed to tell me was everything worked but the 4x4. When I switch to 4 high or 4 low all I get is both hi and low 4x4 lights flashing 4 times every 2 minutes. The 4 wheel drive is not engaging at ll. Where to i look first? Thanks.
Old Feb 13, 2008 | 05:21 PM
gvrangr98's Avatar
gvrangr98
the same thing happened to my truck. generally its the PVH, pulse vaccum hubs that are the problem. its typical on the 98 from what i hear. first you have to look under neath and determine if the transfer case is engageing. hopefully the problem is that the hubs aren't locking in. after market manual hubs are something worth considering. about $100. there are more than a few threads on this subject. as for myself I found a thread called "adding manual control to your 1998-2000 ford ranger" its involves takeing a pair of dykes and cutting out the plastic wagon wheel shape and the metal screen essentially giving you a finger sized hole in your hub so you can lock/unlock your hubs without damageing the vac lines and without spending the hundred or so bucks. that's just me though... I'm cheap. I was sceptical at first but now after about 2 weeks after the modification I'm am more than satisfied with the results. the directions are easy to follow and takes only five minutes a hub.....provided that is your problem. so make sure the differential/transfer case is operating normally. Like I said though I drive a 98 3.0 4x4 and the 4wheel lights out of nowhere started flashing 4-5 times and no 4wheel drive ..the prob was the hubs.
Old Feb 13, 2008 | 05:29 PM
falconqueenD's Avatar
falconqueenD
If It Is The Hubs. Aftermarket Manual Is The Way To Go. From New Wave To Old Way Eh !
Old Feb 13, 2008 | 07:32 PM
huggyjd's Avatar
huggyjd
Thumbs up Hubs
Thanks for the reply. Guess I got a project this weekend
Old Feb 14, 2008 | 06:24 PM
huggyjd's Avatar
huggyjd
hubs
where can I get replacement hubs?
Old Feb 15, 2008 | 11:17 AM
wendell borror's Avatar
wendell borror
You can get the manual hubs from tellico 4x4, there AVM and are the only ones available for the PVH system. There about 100 bucks and it will be fixed once and for all and maaanual hubs can save you a little gas as well.
Old Feb 15, 2008 | 07:36 PM
bluedevil3758's Avatar
bluedevil3758
i have a feeling its not ur hubs, although those should be replaced here, http://www.tellico4x4.com/product_in...ducts_id/26509...
but i would check the shift motor, when my hubs went i could still feel the t case engage and no light flashing, however traction would be the same
Old Feb 16, 2008 | 10:45 AM
huggyjd's Avatar
huggyjd
4x4
I got under the truck today. The shift motor is not working. I put my hand on it and had my son flip the 4X4 switch. Nothing! Maybe a bad shift motor or fuse or something!
Old Feb 16, 2008 | 11:50 AM
huggyjd's Avatar
huggyjd
Does anybody know what fuse to look at under the hood? What would be the name of it? None of the fuses are marked. I have a chiltons manuel but I am unsure about what fuse to check.
Old Feb 16, 2008 | 12:09 PM
wendell borror
Well, thats the other thing that fails, the shift motor, mostly from non use in my experience. I don't know what fuse it is, but there bad for gumming up and not working. 95% of the time it's the PVH, 5% of the time it's the shift motor. Hpefully it's a power issue, but most folks aren't that lucky.
Old Feb 16, 2008 | 11:03 PM
bluedevil3758
im not sure about the fuse but heres a rebuild for it
http://www.explorerforum.com/forums/...d.php?t=123542
also rangerpowersports.com has great info on all things ranger and many sub sections, engine size driveline, suspension etc
Old Feb 18, 2008 | 03:46 PM
huggyjd's Avatar
huggyjd
Every site I go to to buy a new transfer case motor, they do not have one for my 98 ranger. Why is that? They have them from 97 on down and from 99 on up but nothing for a 98. Can I use a differant year motor?
Royce Hagerman
May 28, 2016 09:54 AM
BROWN DOG KTM
Feb 26, 2016 11:04 PM
daviedude
13
Nov 9, 2015 06:24 PM
ddt4812
Feb 9, 2012 11:32 PM
rjeremyj
Dec 28, 2009 09:09 AM
