Cracked transmission case?
Old Feb 2, 2008 | 08:20 PM
orion_134's Avatar
orion_134
I noticed a vibration that got exponentially worse over a day and put it on the lift and the bellhousing is cracked from about the 10 o'clock to 6 o'clock position...fun fun...now, what caused it? I am going to get a used transmission rebuilt by a local shop and hopefully that will last me another 200k, I just want to know if it was an imbalance that caused it or a bearing...the temps never got over 170 since I installed the converter, cooler, vb, and gauge 12k ago...but they most likely did before that. I will be checking the flexplate when I pull the trans.
What years/vehicles have the same transmission?
Whaday'all think?
Jesse
Old Feb 2, 2008 | 08:42 PM
Clubwagon's Avatar
Clubwagon
A cracked case/bellhousing is usually a driveshaft vibration or a bad transmission mount.
Steve
'95 Clubwagon XLT
Old Feb 3, 2008 | 02:11 AM
Sycostang67's Avatar
Sycostang67
It's hard to say since you didn't mention what vehicle you are working on or what kind of tranny you have.
Old Feb 3, 2008 | 06:25 AM
orion_134's Avatar
orion_134
Hmm, thought this place had a signature...oh well, here it is.
Early 1999 PSD 4x4 Auto 220k Superchips Max Tuner, 99.5 PCM, 4" exhaust, 6637, shimmed FPR, CCV, gauges, Harpoon & Hutch mods, 03 headlights, all the bypass filters, Factorytech vb and tc, tru-cool cooler, Warn hubs
Driveshaft imbalance...I replaced all u-joints, the front flange, and the u-joint "barrel" that holds two of them 10k ago, should it have been rebalanced?
Jesse
Old Feb 3, 2008 | 01:40 PM
Sycostang67
You get to have a sig after you reach a certain post count, not sure what it is but it's not very many 10-30 I think.
Not sure about your tranny, but getting your shafts rebalanced after replacing all that stuff sounds like a good idea.
F100Mann
20
Sep 10, 2013 06:41 PM
bigrayjr
Mar 21, 2013 05:12 PM
suds
Nov 8, 2012 05:47 PM
Bucsfan552
Aug 2, 2009 10:21 AM
gunpowder
Aug 28, 2001 12:00 PM
