Strong fuel smell after refuel
Old Dec 13, 2007 | 05:49 PM
David Claflin's Avatar
David Claflin
Trailering
Within the last few weeks anytime after it is refilled there is a strong gas odor around the wifemobile, '03 Expy. There are no leaks or anything on the ground, could this be a purge valve somewhere or something worse, hopefully it's not the gast tank needing replacement.
Anyone come across something like this?
Old Dec 13, 2007 | 06:49 PM
FTE Herman's Avatar
FTE Herman
If it's not a liquid leak, you should get a code P0455 or P0442 if the Evap system is leaking.
Old Dec 13, 2007 | 08:35 PM
04expeditiongrl's Avatar
04expeditiongrl
Close your drivers door when refueling.. j/k
Old Dec 14, 2007 | 11:18 AM
David Claflin
Trailering
very nice.....keep it up and you'll be getting a spanking
Old Dec 16, 2007 | 10:05 AM
Gevans17's Avatar
Gevans17
had similar issue with wife's 89 Aerostar..strong fuel smell right after refueling...turned out to be crack on the top of the plastic fuel tank.
Old Apr 23, 2008 | 08:08 PM
David Claflin
Trailering
I finally got a chance to look at this. Pulled the tank and found stains around filler next attach at the tank. Can't see any cracks though, just stains from obvious leakage.
Old Apr 23, 2008 | 09:46 PM
sbclemens's Avatar
sbclemens
How long does the odor persist? Can you smell the fuel inside the expy?
Old Apr 24, 2008 | 07:20 AM
David Claflin
Trailering
No mostly while outside of it, can't smell it inside. The only time it has left anything on the ground was the one time I parked on an up incline while the tank was nearly full.
Old Apr 24, 2008 | 10:58 AM
Trailblazen's Avatar
Trailblazen
prob a hairline crack right there where you saw the stains.
Old Apr 24, 2008 | 01:25 PM
sbclemens's Avatar
sbclemens
Since you've got the tank off, see if you can pressure test it. If it is a hairline crack, JB Weld maybe able to seal it.
Scootin159
Oct 3, 2013 02:04 PM
Blake Phipps
Aug 24, 2013 11:29 AM
mudstepper
34
Jul 15, 2007 03:50 PM
olfordsnstone
Mar 29, 2005 03:34 PM
granitehauler
Jul 6, 2003 12:09 AM
