intakes
Old May 24, 2001 | 11:51 AM
007truck's Avatar
007truck
intakes
what would be the advantages or disadvantages of a dual port intake from Offenhauser as apposed to their single port intake. The single intake is cheaper. Any suggestion. Which would be better on Gas?
Thanx
Old May 24, 2001 | 11:56 PM
traildawg's Avatar
traildawg
intakes
Do you mean port or plane? If you mean plane, a dual plane would be better for the 4.9L. Single plane manifolds are designed more for racing engines and high RPM use and require the faster intake velocity of high revving to make them effective. A single plane is more aimed at normal street engines operating under about 6000RPM.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Lift w/35's
Auburn Pro-Series Diff. w/4.30 gears
http://www.geocities.com/ProjectTrailDawg
Old May 25, 2001 | 12:24 AM
007truck's Avatar
007truck
intakes
I heard from the parts dealers today that a single plain is better for racing and dual plain is better for everyday low end torgue.
Old May 25, 2001 | 07:29 AM
TallPaul's Avatar
TallPaul
intakes
I assume you are talking carburated 300 I6s. But I always wondered what is inside the plenum on the EFI 300. I assume it is one big box, but if it were divided between the two throttle body barrels (can we call them barrels when it is not a carburator?) then we would have a dual plane intake--right? Or is dual/single plane not relavant for EFI?
Old May 25, 2001 | 09:02 AM
traildawg's Avatar
traildawg
intakes
I got this out of a *cough*Mopar*cough* book I had laying around.
"For most street/strip applications, a dual plain intake will offer the best performance. It's lower plenum height and shorter runner lengths provide for a higher intake velocity which improves bottom end torque. Single plain manifolds are reserved racing engines who's normal operation is above 5000 RPM. This type of manifold usually has a very tall plenum and long, large runners to provide more air/fuel at higher engine speeds."
TrailDawg
1993 F150 2WD
6" Lift w/35's
Old May 25, 2001 | 09:25 AM
TallPaul's Avatar
TallPaul
intakes
I think with the 300 I6 EFI the long (about 20 inches") individual intake runners go beyond the dual plane concept and give it very good low end torque.
Old May 25, 2001 | 11:09 AM
StrangeRanger's Avatar
StrangeRanger
intakes
This came up recently on the Ford Six Performance board.
IIRC the 300 EFI manifold has a divider in the plenum with a notch to allow some bleed from side to side. Very similar in concept and effect to some dual plane carb manifolds with a notch in the divider. it would maintain flow velocity at low RPMs but allow the 2 sides to balance at higher revs.
Old May 25, 2001 | 11:15 AM
TallPaul's Avatar
TallPaul
intakes
Thank you Strange Ranger. Excellent info. Sounds like a winning design.
Old May 26, 2001 | 04:31 AM
phat96's Avatar
phat96
intakes
Hey 007,
Let's get back to your question. I had an Offy Duel Port on a Ford 2.3 Powerd CJ3B many years ago, so I know what your talking about. The Duel Port is like a single plane except the runners are divided horizontaly. This divition is caried back to the carb where the carb primaries and secondaries are separated. The primaries feed the upper half (Port) of the intake runner and the secondaries feed the lower half.
The idea was to promote high speed flow in the upper port (for torque and MPG) and still have the lower for upper end HP when the secondaries opened up.
My little 2.3 was happy with it, and it never acted over carbed even with the 390 Holley on a 140 c.i. motor.
I hope this helps.
John
Old Jun 1, 2001 | 07:52 PM
Taz79's Avatar
Taz79
intakes
My friend has the single plane manifold on his 300, and I have the dual port manifold on mine. Mine has better low end than his does. We are running Offy 4bbl intakes, Dynomax 3 on 3 headers, Edelbrock 600cfm carbs, his is bored .060 shaved .060, Blue racer cam. Mine is shaved .035, with a Crane Cam.
Old Jun 2, 2001 | 05:50 AM
lastchance's Avatar
lastchance
intakes
ColdForge
Mar 20, 2011 03:51 PM
jamies460
May 12, 2008 09:41 AM
JOHNNEHUS
Jul 21, 2007 11:58 AM
phoneman91
13
Oct 30, 2006 06:12 PM
pageparsley
Jan 30, 2005 06:52 PM
