no passing gear
Old Nov 25, 2007 | 01:13 PM
skrinar70's Avatar
skrinar70
no passing gear
I have a 96 F150, 4x4, 302, E40D, The truck drives fine unless you get on it and grab the passing gear, then it builds RPM but doesnt speed up, like a slipping clutch in a manual trans, what is wrong with my truck???
Old Nov 25, 2007 | 01:16 PM
TheRoadVirus's Avatar
TheRoadVirus
Check your trans fluid, if it smells burnt you've probably burned up a band or whatever. Should be red.
Old Nov 25, 2007 | 04:25 PM
skrinar70's Avatar
skrinar70
its still red and doesnt smell burnt, it is not to the top of the checkered section on the dipstick, but its about a pint low
Old Nov 25, 2007 | 08:19 PM
lostin90s's Avatar
lostin90s
Top off fluid the e4od is a testy unit it does not like heat (low or burnt fluid) Or lack of the red stuff. Hope you find a simple fix. Does it shift from 1st to second ok ? lost
Old Nov 25, 2007 | 08:31 PM
skrinar70's Avatar
skrinar70
it shifts through all 4 gears fine, up and down, it just doesn't down shift when you floor it.....
Old Nov 25, 2007 | 08:38 PM
351slug's Avatar
351slug
Have you pulled codes? Could be the TPS. Mine would not downshift when my TPS was acting up. 93 F-150 5.8/E4OD
Old Nov 25, 2007 | 09:14 PM
skrinar70's Avatar
skrinar70
No, I guess I can go to Auto Zone to have that done, thanks
Old Nov 26, 2007 | 06:47 AM
alz's Avatar
alz
Second the vote for TPS.
Old Nov 28, 2007 | 04:22 AM
skrinar70's Avatar
skrinar70
could this be caused by the vehicle speed sensor, that is the only code that came up....
Old Nov 28, 2007 | 08:05 AM
Conanski's Avatar
Conanski
Absolutely.
Old Nov 28, 2007 | 04:47 PM
skrinar70's Avatar
skrinar70
I got a speed sensor today from autozone but I cant find it on the truck, I thought it was on the top of the rear diff, but that ford part number f37f-9e731-aa is an abs sensor, and this part that I got from az
http://www.autozone.com/R,APP542619/...ductDetail.htm
looks nothing like what I have on the tranny.......
Old Nov 28, 2007 | 04:55 PM
Mr. M's Avatar
Mr. M
http://www.autozone.com/R,APP542619/vehicleId,2175602/initialAction,partProductDetail/store,522/partType,00430/shopping/partProductDetail.htm
In a 1996 the VSS and ABS sensor are one in the same. It is located on the top of the rear diff and removes with a 1/2" nut.
Disregard what the guy at autozone told you...
Old Nov 28, 2007 | 05:08 PM
flareside_thunder's Avatar
flareside_thunder
Autozone ****........
JR
Old Nov 28, 2007 | 05:16 PM
skrinar70's Avatar
skrinar70
cool thanks
Old Nov 29, 2007 | 08:28 AM
skrinar70's Avatar
skrinar70
Ok, So I replaced the speed sensor and that did not fix it, no other codes came up, I guess I need to bite the bullet and take it to a tranny shop? Any other thoughts of something I over looked
