I have a 96 F150, 4x4, 302, E40D, The truck drives fine unless you get on it and grab the passing gear, then it builds RPM but doesnt speed up, like a slipping clutch in a manual trans, what is wrong with my truck???
Top off fluid the e4od is a testy unit it does not like heat (low or burnt fluid) Or lack of the red stuff. Hope you find a simple fix. Does it shift from 1st to second ok ? lost
I got a speed sensor today from autozone but I cant find it on the truck, I thought it was on the top of the rear diff, but that ford part number f37f-9e731-aa is an abs sensor, and this part that I got from az http://www.autozone.com/R,APP542619/...ductDetail.htm
looks nothing like what I have on the tranny.......
Ok, So I replaced the speed sensor and that did not fix it, no other codes came up, I guess I need to bite the bullet and take it to a tranny shop? Any other thoughts of something I over looked
