2001 ford f350 turbo cgarger problem
Old Oct 26, 2007 | 11:51 AM
davesworldd2002's Avatar
davesworldd2002
Angry 2001 ford f350 turbo cgarger problem
hello fellow forders,
I have a 2001 ford f350 super duty lariot with a 7.3 liter mtr. I bought the truck a few months ago with only 52,000 on her , alls great. could hear the tubo charger whine and lots of power. Well i have put a few thousand miles on it and rarely ever do i have a need to use the turbo , I drive it like a baby , back and forth to work truck. Now I wanted to see if it still worked , iromped on it and never fellt or heard the charger engage. Since I never used it for a extended period of time did it somehow gum up , clog up or just decide it had enough>? any ideas to get her boosting again , wont be easy on her anymore i promise.....
dave
davesworldd2002@yahoo.com if ya like also
Old Oct 26, 2007 | 12:35 PM
Fat Diesel's Avatar
Fat Diesel
Someone will move this to the PSD forum.
It's time to start saving for some gauges. You'll need BOOST, PYROMETER (Exhaust Gas Temp), and TRANS temp. You'll be able to see how much boost in psi it's making and whether it's up to snuff. What you hear is largely a function of what type of air filter you are running.
Lurk around the 99-03 PSD forum for lots and lots of info on your truck.
Old Oct 26, 2007 | 12:48 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
If you are driving your truck, your TURBO is working. On a stock truck you will not hear the turbo while driving like you said you are driving. You are in the right place to find out about your truck.
If you want to hear the turbo, get a 6637 air filter. But there more than likely nothing wrong with your turbo.
Old Oct 28, 2007 | 05:38 AM
davesworldd2002
hey rick,
I guess the turbo is working. But I never hear it , falls on its *** untill the rpms get up there then feel something. When I bought the truck , twenty thou miles ago , the turbo charger heard like a jet when ya got into it and all kinds of low end rpm power as well. the charger is a garett , is that a stock one.
Old Oct 28, 2007 | 12:04 PM
aldridgec's Avatar
aldridgec
Might need to service the air filter. How's it look? The filterminder doesn't always tell all!
Old Oct 28, 2007 | 06:26 PM
INF GUY's Avatar
INF GUY
well i tell ya diesel engines or made the run and work. Check your air filter or replace it then put the truck on the road. Take a 300 mile or so trip in it towing something. These trucks really arent designed to be babied
Old Oct 28, 2007 | 06:59 PM
ryaneverk2's Avatar
ryaneverk2
Moved to 7.3L PSD section...
Old Nov 2, 2007 | 08:22 PM
davesworldd2002
Cool none
Hey everyone ,
I have checked the air cleaner and is good. I have been looking for air leaks in the turbo hoses. I took a can of carb cleaner and while running sprayed all clamps etc. It did not raise in rpm at all anywhere so I think its leak free. This morning I did notice shortly after I started it I got in and left for a drive I did not really give it its normal 10 minute warm up as I allways do. I turned the corner and gave it alot of gas and there was the turbo again , hmmm. After the motor warmed up good I did the same with no turbo response , Now what? Is this a sign of a hose getting warm and a pin hole opening or what?
Old Nov 3, 2007 | 07:51 AM
davesworldd2002
hey there,
What is the high pressure fuel pump supposed to be ?
Old Nov 3, 2007 | 08:13 AM
Lead Head's Avatar
Lead Head
Do the 7.3s have EBPVs? If they do, maybe yours is gummed up
Old Nov 3, 2007 | 12:14 PM
1996pwrstrk's Avatar
1996pwrstrk
Originally Posted by davesworldd2002
hey there,
Where ?--Under the drivers side in the frame rail about where your feet hit the floor when your behind the wheel.
Old Nov 5, 2007 | 10:05 AM
davesworldd2002
Me again,
What is a symptom of the low or high pressure pump going bad? My truck used to pour out black smoke when ya got on it and now notta , this a symptom?
78F150RangerXLT
Mar 22, 2009 01:56 PM
pdx02
Jan 23, 2008 12:51 PM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
brettwingfield
Sep 16, 2007 09:14 PM
