starter bolt size
starter bolt size
I've got an 82 ford f100 with a 300 straight six and a 4spd manual tranny. I was going through some rough terain and today I went to start my truck and it wouldn't. When I popped the hood I found that both of my starter bolts where missing and my starter was just barely hanging on. I can't figure out what happened to the original bolts, why would they just disapear? I'm sure they came loose or broke off... I can't imagine why anyone would steel them. I need to get some replacement bolts, does anybody know what size I need. I guess I should get the highest grade and a compression washer too. If I just had the diameter of the bolt, I'm sure I could find something that would work.
starter bolt size
The thread is a 3/8-16, which would normally have a 9/16 head. The stock bolts are shouldered and have a 1/2" head to allow wrench access. If you go to the section of the parts store that has Help! accessories you should be able to buy the factory style bolt. You can use a regular bolt with the larger head, but they are a PITA to work with.
starter bolt size
Accessing the starter wasn't a problem in this truck, so I just went with some regular grade 8 3/8-16 bolts with the 9/16 head. $0.29 each sure beats the $2.99 each for the "Help!" OEM style bolts. Yeah, I definately should put some loctite on the bolts. Not using that was probably why I lost them in the first place.
brockathin
08-09-2016 12:01 PM
AZRRC
01-21-2014 12:11 PM
BruteFord
01-02-2014 01:02 AM
andrewscofield
13
07-09-2012 12:53 AM
BORDERBUM
10-07-2011 08:54 AM
