goofy e4od
Old Sep 17, 2007 | 11:29 AM
fe8u's Avatar
fe8u
goofy e4od
every now and then the od light comes on shifts hard, turn truck off then back on all back to normal
did change the vss, waste of money
sometimes it well pop out of gear give it gas and well slam in to gear
what kind of gremlins do i have in my tranny?
thanks chad
Old Sep 17, 2007 | 02:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The only way to know is to have the codes read. The code will stay in memory for about a month after the last time the light flashed. Without the code all you can do is keep buying parts until you find the problem.
Old Sep 17, 2007 | 04:33 PM
fe8u's Avatar
fe8u
forgot it is a 95 f150 with 351 and speed density f.i.
some one told me this year did not have any memory?
Old Sep 18, 2007 | 07:32 AM
Mark Kovalsky
Someone may have told you that, but they are wrong. There's a memory.
The good news is that the '95 F150 was not OBDII, so you can pick up a code reader almost anywhere that sells car stuff for around $25.
