4 Speed Toploader Behind 557ci !!!
Old 07-14-2007, 03:20 AM
jamies460's Avatar
jamies460
jamies460 is offline
Thumbs down 4 Speed Toploader Behind 557ci !!!
Hello, I intend to use my fully reconditioned 4 speed toploader gearbox behind my 557ci , I was out the other day at a mechanic 's shop when I mentioned it to him, the mechanic went on to state that he thinks the Toploader gearbox wont be able to handle the torque of the 557ci engine ! and it will end up blowing up....is this true ??? Thanks Jamie. ( I did tell him that I had the Toploader rebuild- but he still insists it will destroy itself )
Old 07-14-2007, 04:30 PM
darrin1999's Avatar
darrin1999
darrin1999 is offline
from what ive read hes right... there really isnt a good manual transmission option for a 557... it just puts out too much torque. the toploader will work for awhile if you dont powershift, but it will still wear out pretty quick. your best bet is the c-6 auto- anything less is just too short-lived
Old 07-14-2007, 05:30 PM
baddad457's Avatar
baddad457
baddad457 is offline
I used to run small block Toploaders behind a 427 stroker (454) and they held up fine. I don't see why a bigblock Toploader wouldn't hold behind a 557. And I realize that all depends on the actual application as well. Put sticky tires, posi traction and sticky clutches, then dump said clutch at 6 grand, you'll have trouble holding ANY transmission together. I certainly wouldn't be afraid to run a big in/out Toploader behind a 557 on the street.
Old 07-14-2007, 06:13 PM
wizzard351's Avatar
wizzard351
wizzard351 is offline
ive blown top loaders with a 300-6. big in big out top loaders will hold up a lil better but behind a big inch motor i doubt they will hold up.bet a richmond 5-6 speed would tho.
Old 07-14-2007, 07:01 PM
baddad457's Avatar
baddad457
If you're talking about the late 70's to 80's Toploaders Ford put behind the 300-6, I don't doubt it. Those aren't in the same class although they were based on the older ones.
Old 07-14-2007, 07:14 PM
jamies460's Avatar
jamies460
Thanks Guys, As I do not plan to Rev it to 5 or 6'000 RPM then release the clutch hopefully it will last a while, if it happens to destroy itself I will then replace it with a C6 automatic gearbox. I will run a very thick gear oil ( maybe even straight Lucas ) as thats what the gearbox shop recomended when he rebuilt the Toploader.
Old 07-14-2007, 08:26 PM
79superduty's Avatar
79superduty
79superduty is offline
Im using a a 435np and its behind a 557 now for yrs.is that a top loader or no?i have no problem with it .
Old 07-14-2007, 09:17 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,725 Likes on 1,408 Posts
This guy is in 'em up to his elbows. I think a proper one will work behind your motor. Check out the toploader/GV combo. 8 speeds, no waiting....
http://www.davidkeetoploaders.com/to...rpricelist.htm
Old 07-14-2007, 09:24 PM
baddad457's Avatar
baddad457
It is a Toploader type gear box, just not THE Toploader we're talking about. The 435 was a truck transmission, the Toploader was a high performance car transmission. Main difference is the gear ratios and construction.
Old 07-14-2007, 11:40 PM
jamies460's Avatar
jamies460
Hello 85e150six4mtod, that is a pretty good web-site, as I am in Australia i think my rebuilt Toploader came out from behind a high performance 351ci from a late 1960's or early 70's Ford, as i had to purchase a 429-460 bellhousing , is there any way of telling what i have by the numbers on the Toploader gearbox ?
Old 07-15-2007, 03:24 AM
darrin1999's Avatar
darrin1999
maybe pm numberdummy, hed probably be able to tell you what youve got.
Old 07-15-2007, 03:31 AM
wizzard351's Avatar
wizzard351
i was talkin about a toploader from a 65-70 style mustang. i seen them go for up to 1300 bucks today at the swap meet,theres no way i would put them threw that torture when i could sell it so some one that thinks there the best thing since time began and biuld a c-6 or get a richmond for a couple hundred more.as far as in concerd top loaders arnt worth the money
Old 07-15-2007, 09:50 AM
baddad457's Avatar
baddad457
Here's what you want in Id'ing a Toploader www.4speedtoploaders.com This guy has everything you'd need for any Toploader. He even is building completely new ones from the ground up. New cases and tailshaft housings. His site has a completel Id chart to look up the tag numbers. The Id tag is on the passenger side of the main case just behind the belll housing.
Old 07-15-2007, 09:55 AM
baddad457's Avatar
baddad457
The problem is you're shopping in the wrong places. Anything at a swap meet is priced at least 25% above what you can find elsewhere. The Toploader I have in my 89 Ranger cost me all of $150 on ebay. The seller mis-listed it as an SROD. And then didn't post pics and had a "buy-it-now" option. I got the transmission (been rebuilt once in 40 years) an SROD bell and the hurst comp plus shifter for $150. Sold the SROD bell for the $80 the shipping cost me. Been running it for 4 years+ in the Ranger now.
Old 07-15-2007, 12:02 PM
85e150's Avatar
85e150
Kees has id charts also:
http://www.davidkeetoploaders.com/idchart1.htm
Look on the left side for site index.
Good luck.
Quick Reply: 4 Speed Toploader Behind 557ci !!!
