hey all i was just wondering who all had 38-39 ford pickups here and if you could post pictures of them. i love this style of truck and always have my eye out for one but i have yet to find one to make my own. anyways if you have a 38-39 id love to see a picture of it. it doesnt matter if they are stock, restomoded, or full on hotrod custom i like um so lets see um.
my ol man got a 381/2 pickup with hydralic brakes with 43000 miles and is complete down to the oil bath aircleaner but lost keys sucks cause it been sittin for 20 years
Lost keys shouldn't be an issue for letting a Truck sit for 20 years, thats an easy fix and back to original.
Simply take a 1/8th drill bit and under the ignition lock you will see about 1/4 inch hole.
Drill up into it at center and you will feel the drill penetrate the knurled plug. Once this is accompolished, take a sheet metal screw insert it into the drilled plug, take a pair of pliers or vise grips, grip the screw and hit it with a hammer or what ever works.
The plug will come out, then the key code is stamped on the lock cylinder. Now take it to a locksmith and he will cut a key for it.
You can buy the replacement plugs at Dennis Carpenter, or simply use the same plug it will have to be cleaned up a little, but will work.
