Replace head bolts??
Old 07-10-2007, 09:39 AM
jonnybronco's Avatar
jonnybronco
jonnybronco is offline
I am getting ready to rebuild my 1969 429 and want to know if I should replace my head bolts. As far as I know they are the originals. They look good, but I know some people recomend replacing them. From Summit a new head bolt set is about $170 and I don't want to pay that much if it isn't really needed. However, don't want to rebuild again in a few months with a blown head gasket.
Jonny
Old 07-10-2007, 11:04 AM
fasthauler's Avatar
fasthauler
fasthauler is offline
It depends on several factors. Was the engine ever ran hot, (overheated) is the engine going back stock or are you putting on special heads. Is the cam, compression, etc. modified? If this is just a rebuild and nothing more I don't think I would worry about it.
Old 07-10-2007, 01:47 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
even most streetable performance builds the stock 9/16" head bolts are more than sufficient clear up to and past 12:1 compression.
Old 07-10-2007, 01:57 PM
jonnybronco
I don't know if it was ever run hot, the engine is going to gether mostly stock. I did some porting on the exhaust and will be running a RV type cam with propane.
Thanks for the input, I think I will be reusing the old bolts.
Jonny
Old 07-12-2007, 01:20 PM
BChance's Avatar
BChance
BChance is offline
As a rule, I NEVER re-use head bolts. Especially if they are torque to yield design. Even if they are not tty, they stretch, and it is not worth it..Just get some new ones, it's always money well spent.
Old 07-12-2007, 01:28 PM
BChance's Avatar
BChance
BChance is offline
http://headbolts.com/fordcmbb.html
They sell their house brand set for $42.95
Old 07-12-2007, 03:48 PM
ky mustang's Avatar
ky mustang
ky mustang is offline
I would not worry about replacing them unless they look bad , bad threads ,etc,. I have reused factory bolts several times with 13 -13 /1/2 : 1 compression with no problems.
the5schlueters
02-20-2014 12:09 AM
packratF350
16
12-12-2011 07:53 AM
Links56
19
12-24-2009 07:47 PM
masontel
1966 - 1977 Early Broncos
17
06-18-2004 04:37 AM
ecsmith0624
11-29-2003 10:52 AM
Quick Reply: Replace head bolts??
