'51 F2 and F3 brake compatibility
Old Jun 30, 2007 | 10:25 PM
galaxie641's Avatar
galaxie641
I've finally made it to my brakes on the '51 F3 and I have an early build with the dual piston cylinders. Now I am wondering if the F2 and F3's shared the same front drums and/or front shoes, also could they have the same rear shoes? My P. side front drum has a nasty channel cut right in the middle of it and I'd like to replace the shoes since I am in there anyway and the F2 shoes are readily available and of course F3's aren't even listed.
I assume the wheel cylinders are not the same.
Old Jul 1, 2007 | 01:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Early build 1951 F3 uses the same front drums as an F2: 1948/51 = 8 D-1125
1948/51 F3 has 1 3/4" width front shoes, the same as the F2 uses.
1948/51 F3 rear shoes are different than the F2. F3's are 2" width / F2's are 1 3/4" width. (F2's use the same brake shoes front & rear).
1948/51 F2-F3: Front brake cylinders: 21A-2061 right / 21A-2062 left. These cylinders have two sizes. 1 3/8" and 1."
1948/51 F2-F3: There are also heavy duty cylinders. These are 1 3/8" = 8J-2061 right / 8J-2062 left
Old Jul 1, 2007 | 08:59 AM
galaxie641's Avatar
galaxie641
Excellent, thank you That will make getting some of the parts much easier.
Old Jul 1, 2007 | 11:54 AM
ksmith203's Avatar
ksmith203
Great to have numberdummy around, I would not have finished without him and dueller giving me part numbers. I will be needing them both soon again as I start the coe!
1950F2
16
Jan 13, 2013 07:45 PM
GregonVI
Oct 29, 2012 09:13 PM
jmadsen
May 8, 2011 07:15 AM
newblder
Mar 24, 2010 09:04 PM
hines182
Dec 6, 2006 12:53 AM
