Sponsored by: Auxito
what size wheel and tires?
Old May 10, 2007 | 08:27 AM
tgowers's Avatar
tgowers
what is the larget size wheel and tire combo that will fit on a stock 98 f-150 4x4, and the stock wheels are 17 inch. i am want a larger diameter wheel with an agressive tire. i am really liking the low profile off road tires. this is all new to me becasue i have a 68 f-100 that is on the ground. thanks guy, and if anyone has any pictures that would help too. thanks, tony
Old May 10, 2007 | 01:08 PM
preppypyro's Avatar
preppypyro
You could definatly put a 265/70/17 on there. Im pretty sure a 285 will fit, but I wont guarantee that one.
Old May 10, 2007 | 01:11 PM
tgowers's Avatar
tgowers
how tall is that? 31, 33?
Old May 10, 2007 | 01:15 PM
preppypyro's Avatar
preppypyro
A 265 is 31 inches, and a 285 is 33.
On my 97 I had 285/75/16s, which is a 33 inch tire, and it fit fine, thats why I think a 285/70/17 would fit on yours.
Old May 10, 2007 | 02:07 PM
galaxie641's Avatar
galaxie641
285's are the safest, some people have run 295's and claimed no rubbing while others have, 305's will definitely rub. I've run 285/70/17's with no problems but it is hard on the brakes and front suspension.
Old May 10, 2007 | 04:11 PM
preppypyro's Avatar
preppypyro
I could see how a truck could brake a little poorer with a larger tire on there, but how would a 2 inch overall diameter tire, be harder on the suspension?
Old May 10, 2007 | 05:19 PM
galaxie641's Avatar
galaxie641
Heavier tire, stiffer ride more surface area to turn all contribute. I broke 2 sway bar endlinks after going to 33's, since I've gone back to 265/70/17's I have yet to break one for one example.
Old May 10, 2007 | 07:31 PM
Mustang Maniac's Avatar
Mustang Maniac
Tire and Wheel Choices
There are a lot of possible tire and wheel combinations that will fit. Suggest you visit this site to see all the possibilities.
http://www.americastire.com/dtcs/home.do
Good Luck in choosing.
Old May 10, 2007 | 10:30 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
One of mine broke when I put my 33's on...so I unbolted the other one and zip tied the sway bar up. Problem solved. Plus, there's a little more flex offroad...
Old May 10, 2007 | 10:39 PM
dilas's Avatar
dilas
I have 285/70/17 on mine. It's fine, no rubbing. It's 33". If I had to do it all over, I would have stayed with stock 265/70/17 as I lost about 1-1.5 mpg overall. Not that bad but lose around 25-30 miles per tank.
Old May 11, 2007 | 04:51 PM
B's FX4's Avatar
B's FX4
yeah i put 285s on and lost mpg as well, but i gotta say they look and perform great, thank god i have my mazda for mpg.....
Old May 11, 2007 | 07:33 PM
galaxie641's Avatar
galaxie641
I went back to 265/70/17's I think it is a happy medium, although 33's look damn good in the fender openings.
Old May 11, 2007 | 11:11 PM
preppypyro's Avatar
preppypyro
For you guys that lost mpg, was that on the highway, or in town? When I went with the larger tires on my truck, I gained 1-2 mpg, on the highway. In town I lost probably more then that though.
sig6060
2009 - 2014 F150
Oct 30, 2012 01:17 PM
Xistenz
1983 - 2012 Ranger & B-Series
Dec 8, 2010 04:31 PM
caps2216
Jun 18, 2010 11:47 PM
AntiHero55
Jun 3, 2010 04:56 PM
WILLIAM HORNSEY
2004 - 2008 F150
Mar 6, 2006 05:55 AM
