Sponsored by: Auxito
F-150 problem
Old May 7, 2007 | 09:09 PM
kdrifter440's Avatar
kdrifter440
F-150 problem
I got a 97 F-150 4x2 4.2 liter automatic
The thing shakes at 40-45 miles per hour and stops shaking a 50 mph
It shakes harder going up hills
I have been trying to figure it out for months now...
I had a bad UV joint that was frozen when this problem started
I changed rear end fluid...
Rotated balanced tires...
I thinking of ordering a used drive shaft does any one else think that the drive shaft could be messed up?
Old May 7, 2007 | 10:06 PM
Ultramagdan's Avatar
Ultramagdan
Have you checked the TSB list above? I doubt it's your drive shaft but I would recommend looking at the TSB's and seeing if the problem is listed. Here's the link: https://www.ford-trucks.com/tsb/tsb.php
Old May 7, 2007 | 11:48 PM
daddyd5150's Avatar
daddyd5150
I agree with Ultramagdan that it probably isn't your driveline. I have never experienced a driveline problem that gets better with speed.
Old May 8, 2007 | 08:51 PM
kdrifter440
Yeah there is nothing on that list
Old May 8, 2007 | 10:31 PM
1964FORD4ME's Avatar
1964FORD4ME
The only thing I have ever had act like that was the housing that holds the cluster gear broke it only shook going up hill. However it could be a coil or fuel problem also.
Jason
