Have you checked the TSB list above? I doubt it's your drive shaft but I would recommend looking at the TSB's and seeing if the problem is listed. Here's the link: https://www.ford-trucks.com/tsb/tsb.php
The only thing I have ever had act like that was the housing that holds the cluster gear broke it only shook going up hill. However it could be a coil or fuel problem also.
