Remove Tranny Fluid Bypass?
Old May 7, 2007 | 02:02 AM
SpringerPop's Avatar
SpringerPop
I've been thinking about doing this, as I never have to drive where it might be real cold. Even so...
It's just a nagging feeling I have that it could fail open, giving me bypass all the time and no tranny cooling.
Auto trannys lived for decades in freezing weather without the need for this, so I sorta' wonder just how "necessary" it really is.
Seems like it could be of very marginal necessity, with potentially catastrophic results if it fails.
Any knowledgeable thoughts out there?
Pop
Old May 7, 2007 | 06:26 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I don't have a personal opinion, but Brian at BTS replaces every one with a new one when he installs new trannies. He says keep it. Hot fluid is better than no fluid!
Old May 7, 2007 | 11:02 AM
SpringerPop
Kris,
That doesn't make sense to my old, sometimes not-so-well-used brain. Under what conditions would I get "no fluid"? A pinched line or clogged cooler? That would make sense only then, but as I said, trannys have lived (since the late '40's) without this added "enhancement", and it's just one more thing to go wrong. And when it goes wrong, it creates a problem that never existed in history.
Pop
Old May 7, 2007 | 01:08 PM
John311t's Avatar
John311t
I'd say if you do not drive where it is cold than get rid of it. Like you said, if it goes wrong, more problems.
Old May 7, 2007 | 02:23 PM
Kwikkordead's Avatar
Kwikkordead
I think that's good idea. I've often toyed with that idea if I had an automatic.
And as an added margin of safety you could rig up a buzzer to a pressure switch that closes if pressure gets too high on the feed side of the ATF cooler.
Old May 7, 2007 | 03:31 PM
SpringerPop
Oooooooo! Pressure switches I gots!
Thinkin', thinkin'...
Woo-haaaaa!
Kwik, you sure think deep for a non-math whiz!
You 'da "go-to" guru!
And now, for the next LED on the instrument panel...
Pop
Old May 8, 2007 | 12:50 AM
Kwikkordead
Well thank you Pop.
It just seemed logical to assume that a clogged cooler would jack the pressure up on the feed side.
I have a thought: With the bypass eliminated all the fluid is going to go through the cooler, even in the dead of winter. You may need to put a temperature or time delay in that warning system that turns off the buzzer until a certain temperature or time delay is reached or you will have an annoying false alarm every morning.
Old May 8, 2007 | 01:07 PM
SpringerPop
I can deal with an illuminated LED if I know the cause.
No buzzers on this one!! ;-)))
Pop
Old May 8, 2007 | 01:51 PM
cangim's Avatar
cangim
All i can say is make the LED flash rapidily so as to get you attention. if you are good with electronic look up 555 timer. Fairly simple to make and you can adjust the flash rate to what you want
Old May 8, 2007 | 05:45 PM
SpringerPop
Been using -555's and -6's since the dawn of time. Actually, since the mid-'70's or so.
Great chip that has a LOT of uses. Timers, oscillators, missing pulse detectors, etc. They are still produced, to this day!
I still dig into an old dog-eared Forrest Mims book once in a while for ideas.
Pop
Old May 8, 2007 | 08:13 PM
bigtorque's Avatar
bigtorque
fyi, a friend of mine had a problem with his bypass while towing 7K. tranny overheated about every 20 min or so, and had to let it sit for about 45 min in order to get it home, now i dont recall what the issue exactly was, (maybe bypass switch or something) but he replaced the part and no more problem,
Old May 8, 2007 | 09:45 PM
jtharvey's Avatar
jtharvey
I would tend to agree with Kris, and keep it. Like he said, hot fluid is better than no fluid. If the cooler clogs or your filter clogs & the filter bypass fails, and you lose fluid flow, the transmission would likely suffer damage in a short time. A pressure warning switch may just alert you to the damage done. At least if the bypass fails, your trans temp gauge will give ample warning that the fluid is getting hot before major damage is done. Plus, how many bypass tubes have we heard of failing?
Old May 8, 2007 | 10:15 PM
Kwikkordead
So I have a six speed transmission with a factory ATF cooler that runs to the bottom of the radiator. There is no bypass valve installed.
Before we shoot down Pop's idea of getting rid of the bypass valve answer me this question. How long have bypass valves been installed on automatics.
If for not very long, then what happened before that?
Old May 8, 2007 | 10:22 PM
SpringerPop
Kwik,
That's the question I originally asked, and the reason it seems to be a possibly unnecessary complication. A lot of downside for only a little benefit. The upside is the tranny comes up to operating temp faster. That might make sense if I lived in Alaska or Minnesota. I'm in SoCal!
Since I don't have a trans temp gauge, the instant pressure builds up in that cooler line that's beyond the pre-set limit of the pressure sensor switch, I'll know it. Much faster than a temp gauge, and no harm done to the trans as a result.
Pop
Old May 8, 2007 | 10:23 PM
PowerstrokeJunkie
Marv how do you know what pressure to set the switch at? What is normal line pressure?
