Pedal feel after disc conversion
Old May 1, 2007 | 03:10 PM
Midnite Cruiser's Avatar
Midnite Cruiser
Flush with victory after a toysteer conversion, we moved into more modern brakes.
I stuck with the stock 5x5 1/2 wheels so used 1980s vintage front ventilated rotors, big GM calipers. Leery about being overboosted with stock pedal arm leverage, I did not go boosted at all. Mid Fifty sold me a 68-72 Mustang dual master cylinder, bracket etc. We used a proportioning valve from a 69ish Econoline.
After many bleeds, we still get a softish pedal. It bites about 1.5 in down like the stock master, but mushes down to about 2 in from the floorboard with pretty constant resistance (and good braking).
I guess Im used to the rock hard stock master. Any chance the new master isnt cutting it? or pads need to seat or something?
Im all ears
Old May 1, 2007 | 05:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Something ain't right. It may not be the new fronts, check the rears as well. I assume the M/C is a disc/drum Mustang unit?
Old May 1, 2007 | 05:31 PM
49fordpickumup's Avatar
49fordpickumup
Brakes
Jay, You didn't say if the rear was disc. During the 60's was the change over to disc. Several vehicles had a choice of drum or disc. Also master cylinders are different for drum/drum, disc/drum and disc/disc front /back combinations. Make sure you have the correct m/c. I would have installed a power booster. I don't know anyone who didn't upgrade to pwr boost with disc/disc. Did you bleed with pressure kit or by pedal only? Was porportioning valve for a disc/disc,disc/drum or what you have? Keep m/c fluid full. Hope this helps. Have a great day,chuck
Old May 1, 2007 | 06:27 PM
rhopper's Avatar
rhopper
Assuming the flex lines are in good shape, bled properly, etc you may be describing a "long pedal". A long pedal has a long travel to actuate the brakes, then has a firm pedal once they bite. It's usually caused by a mc that is too small, so it makes up for the small diameter piston with longer travel. Is the mustang mc a drum/drum or a disc/drum? Do you know what diameter the pistion is? You mentioned BIG Gm calipers, how big? Did you rebuild the rear drums at the same time? Improperly adjusted shoes will also give you a long pedal. You may want to jack the truck, and slowly apply the brakes while you turn the front and rear wheels, to see if one end is grabbing before the other. Maybe you can isolate it to front or rear. Keep in touch. -Rusty
Old May 1, 2007 | 06:44 PM
dffay's Avatar
dffay
It might mean some more time spent with the proportioning valve too. There should be a slight lock-up first forward then rear---(so the rear doesn't fishtail too soon) As for the feel, it is the brake drum set up that to grab and the disc set up that operates more in a linear fashion. I'd also think about seating the discs and drums in before further adjustment. Those are brand new surfaces that are getting used to mating
Old May 1, 2007 | 07:03 PM
51dueller's Avatar
51dueller
I think the problem is the proportioning valve as the Econoline's never got disc brakes until 1975.
Old May 1, 2007 | 07:12 PM
raerjim's Avatar
raerjim
I shall now display my brake ignorance for all to see and ridicule. The bed boards are out of my truck, and attached to the Ford 9" rear (drums) axle is what I assume is the proportioning valve. The strange part is, and I am certainly no brake expert, is that it has a length of 5/16 hose exiting it, vented to atmosphere. I have never seen a "vented" P.V.???? I have Cordoba front clip with Chrysler discs, and I too have what I consider excessive pedal travel. Stops great, rear shoes are correctly adjusted. Just 5-6" of pedal travel b-4 good braking.
Old May 1, 2007 | 07:48 PM
51dueller's Avatar
51dueller
I assume you mean the junction block the brake hose it attached. The hose is just for axle ventilation similar to a road draft tube.
Old May 2, 2007 | 09:02 AM
Midnite Cruiser
Fact check:
Calipers from 89 Caddilac
Proportioning valve from Ch**y van about same era, had disc/drum
I stuck with rear drums-only about 2000 mi on completely new cyl, hoses, shoes, drums
Mid Fifty item 5914 Master cyl "Designed for all drum applications AND disc front/drum rear"
I will go thru another bleed after driving some more to chase out any more air if its there. After that, I suspect the M/C is either the wrong one or not working right.
Old May 2, 2007 | 09:45 AM
merlynr's Avatar
merlynr
I did the Granada front disc conversion on my 65 Mustang and used a 67 master cylinder and a prop valve off of a Fairmont of 80ish vintage and it worked great after plumbing in for prop valve and repositioning soft lines.
Some calipers can be installed on the wrong side of vehicle and the bleeder is not the highest point on the caliper and therefore you can bleed brakes til cows come home and you won't get all the air out. I don't know if yours are like that or not, but it is something to check.
Old May 2, 2007 | 11:16 AM
CharlieLed's Avatar
CharlieLed
If the calipers are higher than the MC then fluid will bleed back (actually just the pressure reduces) and require more brake pedal to get the pressure back into the lines. There are devices, like a proportioning valve, that act to hold pressure in the lines so that you don't have to push the pedal so hard every time you actuate the brakes. I don't recall the technical name for these inline devices but you can get the scoop on them from any of the brake suppliers.
Old May 2, 2007 | 12:01 PM
rhopper's Avatar
rhopper
Charlie, good point! Those are residual valves, or residual pressure valves. They're a one way valve to prevent just what you're talking about. Available from pretty much all the vendors. You need a different pressure for disc and drum, but the psi you need escapes me. They just plumb into the line.
Old May 2, 2007 | 01:25 PM
AXracer's Avatar
AXracer
Yes, unless the proportioning valve has them built in (doubtful in this case) you need a residual valve plumbed into the the front and rear line after the proportioning valve with an underfloor MC. A 2# valve (usually designated by red color) goes in the line to the front brakes, a 10# valve (blue) in the rear brake line for disk/drum applications.
Old May 2, 2007 | 08:28 PM
1low50's Avatar
1low50
if you go with the willwood valves then the 2 psi are blue and the 10 psi are red.
Old May 3, 2007 | 07:58 AM
Midnite Cruiser
Guys, sounds like you nailed this one. I will put on the 2/10 backflow valves and probably an adjustable proportioning valve. (The rears are locking up a little bit early unloaded)
I wont condemn the master until all the new valvling is in.
