84 F-150 Carburetor or Fuel Problems???
Old Apr 28, 2007 | 09:32 PM
mjg's Avatar
mjg
Cool 84 F-150 Carburetor or Fuel Problems???
Hello, I have a 1984 F-150 4x4. I've owned it since 1987. bought it off the original owner. It had 34000 miles on it. Loved it. At 97000 miles it spun the cam gear. Bent 8 valves. I had a good friend fix it for me. He told me I should get 50000 miles out of the rebuild. I had well over that. Several years later the bottom end started to show signs of wear and lack of power. In the morning starting her up no problem. Oil pressure is good power is good. Until she warmed up on the way to work. She wouldn't even get out of her own way. That went on for a while until i had the motor sent to Jasper Engine to have her re-built. Over $5000.00 later she is running excellent. Oil pressure, Power..etc. Until last summer i noticed one evening on the way home from work i noticed some hesitation. Didn't think much of it. Well it proggresively got worse. Now the hesitation is violent. Bucking and cutting out. Then after it cuts out it comes right back runs good for a while. I went thru everything. Plugs, Wire set, cap&rotor, Coil, Module, Pick-up, Fuel filter (in line). Had the Carb cleaned. supposed to have been a $100 re-build. The Oxygen sensor is the latest part i changed. Seemed to run good for a few days. Back to the same old thing. I think it is the Ethenol in the gas. Seems like water in the gas. Doesn't Ethenol obsorb moisture??? I'm going crazy. Has anyone heard of or has had any of these types of symptoms. It would be greatly appreciated. MJG
Old Apr 28, 2007 | 09:49 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site!
You have a few problems with your truck and the good thing is that there are a lot of answers here. Just post your question in our tech forums by clicking on the Forums tab at the upper left and scroll down through the list. There is a forum for your year of truck and another for your engine. Try 'em out!
Old Apr 29, 2007 | 07:39 AM
mjg's Avatar
mjg
Ultramagdan, hello, i'm new to this. I must be stupid. How do you post a question?
Old Apr 29, 2007 | 09:23 AM
Ultramagdan
No problem! I assume you want to post in this forum:https://www.ford-trucks.com/forums/forum37/
When you go into it, on the left side is a blue tab labeled new topic. It's not real big but you'll know it when you see it. Click on it and type in your question and title. At the bottom will be the tab to submit the new thread.
That's it!
gampas twuck
New Member Introductions
Jul 7, 2007 12:20 PM
Jeffypop
Jan 22, 2007 06:36 AM
CRGIFT
Jan 8, 2007 07:26 PM
charles johnson
Dec 31, 2006 01:57 PM
