Intermeitent stalling
Old Dec 30, 2006 | 01:31 PM
charles johnson's Avatar
charles johnson
1988 F-150 6cyl 300 v6 2 years ago truck stopped. repair was fule pump in rear tank. Since then it stalls every 3 to 5 months so they put a in line rail fule pump. Still 3 to 5 months i go thru the same thing. 2 weeks ago it stalled i just walked home. 2 days later i went back and started. It stopped 3 days later so i put a new rail pump on. It would not start. Then i put the old one back on and it started. Every day or 2 its stops. Got under the hood and pulled relay pulls apart and back together, this made it work. It if stops now i bang the relays a off it goes. Does anyone have a clue what i can do?
Old Dec 30, 2006 | 03:22 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome to the site!!!
I would recomend you post your question in the fuel delivery forum.
Should see more responses there
https://www.ford-trucks.com/forums/forum72/
Old Dec 31, 2006 | 01:31 PM
charles johnson
I'm New
Who Do I Get To That Area Sir?
Old Dec 31, 2006 | 01:57 PM
Ultramagdan's Avatar
Ultramagdan
You can click on the link that Big put in his message.
Or you can click on the forums tab at the upper left. Clicking on it will display all of the tech forums and you can then browse over them and select the one you want.
Good Luck!
jonvanzanten
New Member Introductions
Sep 8, 2007 12:07 PM
gampas twuck
Jul 7, 2007 12:20 PM
mjg
Apr 29, 2007 09:23 AM
Bludoe
Apr 28, 2007 09:36 PM
wstocks
Feb 5, 2007 04:13 PM
