Holley fast idle issues
Old Mar 19, 2007 | 08:02 PM
yellow78ford's Avatar
yellow78ford
I have a 351m with a holley 4160 600 carb with electric choke. Here is the problem. My fast idle does not work initially, on the first start of the day. I go outside, pump the throttle, the choke closes, the truck starts, but I have to sit there, with my foot on the throttle, to keep it from dying. After about a couple minutes, I can let off the throttle, and the idle starts to climb to it's 1600 rpm. I go back outside, blip the throttle, and it idles to it's normal warm idle. I drive the truck to school, it sits outside for about 3 hours. I pump the throttle once, and the fast idle works as it should. It works but does not work when the engine is completely stone cold (sitting over night). My choke is set at the last notch (slowest opening).
Old Mar 19, 2007 | 08:44 PM
LxMan1's Avatar
LxMan1
Sounds like the fast idle cam is sticking. Try spraying some carb cleaner on the choke linkage between the choke cap and the side of the carb.
Old Mar 21, 2007 | 12:36 PM
yellow78ford
That definetly worked. How should I keep the mechanism lubed correctly? Sometimes, not only does the fast idle not work, sometimes the choke gets frozen open in extremely cold temps, so I have to push on the flap with my hand.
Old Mar 21, 2007 | 04:59 PM
LxMan1's Avatar
LxMan1
I have learned over the years that spraying lube on the linkage will make it gum up faster. So just the seasonal spray down with carb cleaner works the best for me.
Old Mar 22, 2007 | 10:40 PM
73F100*8Mile's Avatar
73F100*8Mile
Dry graphite spray
Old Mar 23, 2007 | 12:29 AM
kermmydog's Avatar
kermmydog
I believe your problem is your choke setting. I have an 86 460 with a 4160 600 CFM Holley. I run a lean choke setting & on cold mornings (20 degrees) or colder I have to do the same thing. With a rich setting believe it or not I don't have that problem but I also drop about .5/gal in gas mileage. Using the marks on the chock isn't always right. You can PM me if you want to talk more on this.
yabadaba
May 15, 2016 10:29 AM
Brian4618
Oct 30, 2015 09:30 AM
okie72
Jan 29, 2014 09:32 PM
1982fordf100
Sep 5, 2006 09:20 PM
farmnaggie
Apr 29, 2006 09:12 AM
