Quick turbo help please! H2E or GT38?
Alright, I need to order my stuff ASAP, but have been getting conflicting information. I want a turbo to tow with at 400 hp, and no issues. Sound is not important here. My biggest concern with the H2E is smoke and spool time. Concern with the GT38 is excessive backpresure at high boost levels when towing long hills. I would like some feedback from actual users, especially low RPM smoke issue with the H2E. Looking at stage 2 with stock nozzles.
I got to Order my stuff!!
A possibility to consider is a GTP38R with a 1.15 A/R turbine housing. I know you are trying to save a bit of money on your overhaul. The turbo is $1600, the housing is $350, and the flange adapter is $100. So you're $400 cheaper than the H2E. Plus with the 1.15 housing, your exhaust backpressure is lower and you can run a little higher boost with your Stage II's. Beans sells the housing and flange adapter.
considder that, GTP38R is not rebuildable turbo, so somthing goes bom! and you SOL, H2E on the other hand is , i was thinking about it, with my stage 3 injectors, but decided on H2E, ill let you know maybe next weekend, when i get to install it,
and H2E will never surge, and if you ever think of more upgrades you can always groe to H2E,
good luck FN
good luck FN
abowman
23
10-04-2019 01:52 PM
ScaldedDog
40
11-15-2013 12:20 PM
dentsideranger
13
04-18-2012 07:25 PM
superduty4x4
03-03-2010 01:57 PM
